After we had a whole series of large air coolers on the testbench, including the almost gigantic be quiet! Dark Rock Pro 4, let’s look at the other extreme today. Whether this small cooler and its 92mm fan can tame a Ryzen 9 – and under which conditions – you can find out in the following article.
The cooler comes in a handy box, completely printed in black and nicely illustrated. A table on the side informs us about the details, but more about that later.
Inside, two blocks of foam and a small tray of plastic protect the delicate cooling fins from damage from transport.
The included accessories are manageable, only the brackets for the different bases including screws and a small tool are included.
Assembly and installation
Depending on the socket, you attach the corresponding bracket to the heatsink with four screws and then fix it with four more screws from behind through the motherboard.
It could hardly be any easier, I have rarely installed an air cooler so quickly.
Specifications
Here is an overview of the technical details, further information can be found on the product page of the manufacturer.
be quiet! Pure Rock LP (BK034)
![]() | Lagernd, Lieferung 1-2 WerktageStand: 16.07.24 08:06 | 42,83 €*Stand: 16.07.24 08:17 |
![]() | Lieferzeit 6-8 Werktage | 42,84 €*Stand: 16.07.24 08:02 |
![]() | siehe Shop | 44,67 €*Stand: 16.07.24 08:17 |
20 Antworten
