Case Reviews
BeQuiet! Light Base 900 FX review – Airy dual-chamber case with cyberpunk vibes and extreme capacity
The fact that the traditional German manufacturer BeQuiet! is also increasingly reaching for the shelf with the glass panels and RGB lighting is a thorn in the side of many “silent freaks” for good reason. Read on to find out why the new Light Base series could still be a big hit.
I won’t deny that large glass panels and mesh inserts are nowhere near as “quiet” as closed, insulated steel panels. And of course you can’t override these physical laws by adding brightly colored lighting or circumvent them in any way. It is therefore quite justified that true “silent freaks” (the term is expressly not to be understood negatively!) view this development critically and fear that the so aptly named company BeQuiet! could stray from its actual path. At this point, however, it must also be mentioned that the case series presented today is called LIGHT Base and is not primarily aimed at our quietest users.
The Light Base series comes in the smaller 600 and the larger 900 version shown here and will be available in black and white, as well as with (FX) and without (DX) pre-installed RGB fans (Light Wings). Even though the Light Base 900 is anything but “compact”, it does not look as bulky as the representatives of the big or full tower format, such as the opulent Dark Base Pro 901 or the tall 7000D tower from Corsair. Nevertheless, the “large” Light Base holds practically as much as the two aforementioned tower cases combined and, with this capacity, can even accommodate gigantic water circuits with two 420s and a 360 radiator (at the same time!). The whole thing comes packaged in an outer shell with an extensive light show and includes many features familiar from the Dark Base, such as inverted motherboard mounting. But before we get lost in technical details, let’s first unpack the case together.
Unboxing
The outer box is unspectacular as usual. And yet it immediately reveals a special feature of the Light Base series.
After unpacking, it took a moment to realize where the front and back or top and bottom actually were. The removable feet finally gave it away.
If you don’t move with the times, you have to move with the times. This format is well known by now.
The right-hand side panel is completely perforated to ensure maximum airflow. The discreet rubber feet prevent the desk from being scratched when it is positioned horizontally.
A little fiddly but consistent: dust filter over the entire surface!
With its many closed surfaces, the rear looks almost misconstructed, but it fulfills its purpose and ensures a certain stability.
The floor, which can also be the lid. More on this in a moment.
And here too: Dust filter over the entire surface, but even more fiddly to dismantle.
The feet can simply be “twisted off” and refitted on the other side, so the lid quickly becomes the base and the case is inverted: Mainboard upside down, glass panel on the right-hand side.
Speaking of glass panels. This is 4 mm thick and is fixed in place with a sturdy suspension solution:
The small glass panel (front) is fixed at the side with screws.
The same suspension solution is used on the surface.
Let’s take a look at the main chamber first.
A stable support for heavy graphics cards is always welcome, especially when it has as much clearance as in the Light Base!
Cable outlets as far as the eye can see and all those “in the field of vision” are fitted with thick rubber grommets.
There is a good 6 cm of free space above the board – enough room for a radiator and fans without even coming into contact with the mainboard’s cooling system or the memory bars.
The bracket for the PCI(E) slots can be rotated to allow vertical graphics card mounting. In principle, I like the idea very much, but here again – typical “German engineering” – it is far too complicated to implement. Five screws have to be loosened and moved and the mainboard also has to be removed for the conversion due to the hanging mechanism.
In the base (as well as in the lid) we find a bracket for mounting a radiator / AIO cooling solution / case fans, conveniently and with enough space outside the case.
The centering Nubsi of death! There is definitely no devaluation necessary 😉
echolot
1,202 Kommentare 943 Likes
Merci für das Review. Mit der Möglichkeit gleich zwei 420er Radiatoren zu verbauen, ist das Aquarium gut gerüstet für einen Customloop. Ich weiß aber noch nicht so recht ob mir die seitlichen LED Streifen gefallen. Too much irgendwie.
Rizoma
247 Kommentare 212 Likes
Schönes Gehäuse aber von BQ nicht zu ende gedacht. Die Reverse Lüfter kann man nicht einzeln Kaufen warum auch immer ... (Ihhh Kunde bringt Umsatz). Liegen aber nur 3 dabei die meisten werden ihren Airflow in so einem Gehäuse aber so bauen das man 6 Braucht (3 an der Seite und 3 Unten) Also komplett ohne Lüfter kaufen und auf andere Lüfter setzten.
1,901 Kommentare 1,192 Likes
Ja, mir ist's auch etwas zuviel Disko Atmosphäre, aber wenn sich's verkauft...
@Alexander Brose : Guter Test; und Frage: es sieht so aus, als ob sowohl der hintere als auch die drei vorderen Lüfter in das Gehäuse rein blasen, ist das so richtig? Wenn ja, sind die oberen Lüfter dann die Entlüftung, und wie viele gibt's davon dann; 2 oder 3? In dem Fall wären 2-3 Lüfter die von unten Kaltluft zuführen auch noch gut, um die GPU bei Laune zu halten.
Rizoma
Der hintere ist Outtake die 3 seitlichen Intake. Ich persönlich würde so ein Case so betreiben
Unten 3x In
Seite 3x In
Hinten 1x Out
Oben 3x Out
ssj3rd
243 Kommentare 171 Likes
Schönes Teil, könnte mein Dark 900 (Rev 2) nächstes Jahr ersetzten beim Aufrüsten, obwohl ich persönlich nur eine AIO einbauen würde, ich mag (sehr) viel Freiraum:
+1 für R2D2 im System 😄.
Noch ein paar Anmerkungen zum Design:
Da wir hier ein Gehäuse vor uns haben, daß sich im höheren Preisbereich tummeln will, hätte ich auch noch gerne 1 zusätzlichen USB-C Port gesehen (also insgesamt 2), einer davon auch explizit für USB-4 und Thunderbolt geeignet wenn das Board und der Chipsatz sowas unterstützt. Bei mir hat sich noch niemand beschwert, daß er zu viele leicht zugängliche Anschlussmöglichkeiten hat. Umgekehrt aber schon.
Und, Vorschlag an @BeQuiet! : Eine leichte Mulde mit Qi Ladefähigkeit fürs Smartphone im rechten Bereich des Tops rechts (von vorne) als Option anbieten. Wär doch ein schönes "Feature". Wenn ihr (BeQuiet!) das aufnehmt und es ankommt, könnt Ihr Euch gerne mit einem Gutschein erkenntlich zeigen 😄.
A
Avir
3 Kommentare 0 Likes
Schöner Test,
Bei mir stellt sich die Frage, passt da noch eine Soundkarte rein, wenn ich die GPU "hochkant" verbaue?
Rizoma
Nur eine USB Soundkarte. Keine PCIe es sei denn du bindest diese dann ebenfalls mit einem Riserkabel an. Was aber keinen Sinn macht da man ja seine Graka wegen der Optik vertikal verbaut und diese ja dann wieder von der Soundkarte verdeckt wird wenn man diese mit Riserkabel einbauten würde.
A
Avir
Danke,
Sind die PCIe eigentlich generell besser als die USB?
ssj3rd
Kann man pauschal so nicht beantworten, gibt ja auch sehr hochwertige USB Soundlösungen.
Q
Quarks
16 Kommentare 11 Likes
Hallo Igor,
danke für die ausführliche Vorstellung des Gehäuses ! Aber ich bräuchte mal ein wenig Hilfe bei der "Räumlichen Vorstellung". Das Gehäuse kann ja auch liegend (also so wie früher die Desktop Gehäuse) betrieben werden. In meinem Hirn wollen sich da grad nicht die äußeren Abmessungen "sortieren".
Wenn ich dieses Gehäuse also hinlege so das die Glasfront vorne und oben ist, welche Abmessungen habe ich dann ? Breite=532 mm, Tiefe=484mm und eine Höhe von 327mm ?
Das wäre dan liegend montiert ein ganz schöner "Klopper". Fände ich aber wg. der dann stehenden GraKa besser.
(Ich bin grad auf der Suche nach den Teilen für einen neuen Rechner, bin aber was die Gegebenheiten in meinem Arbeitszimmer/Homeoffice von den Stellmöglichkeiten beschränkt. Rechts neben mir passt es weder auf noch unter den Schreibtisch. Ich habe nur die Möglichkeit es links neben mir zu stellen - könnte dieses Gehäuse also nur liegend betreiben, denn stehend würde man die Innereien nicht sehen)
P.S.: Das neue System soll mit Wasser gekühlt werden und da dieses Gehäuse Platz für 2 getrennte oder einen "superfetten" Kreislauf mit mehreren Wärmetauschern bietet könnte man das System vermutlich sehr leise bekommen mit langsam drehenden Lüftern.
Allerdings dürfe das Gehäuse dann auch nicht größer ausfallen. In der Stelltiefe bin ich leider auch beschränkt - die 484mm (wenn ich das richtig sortiert habe) sind schon grenzwertig...
Grüße
Quarks
Q
Quarks
Puhh - habe so eben auf der bequit! Seite gesehen das man das Gehäuse auch so umbauen kann das die Glasfront rechts ist, somit könnte ich das Teil auch stellen und nicht nur legen...
Das ist doch mal etws :)
Grüße
Quarks
M
Marc
2 Kommentare 0 Likes
Sehr guter und detaillierter Bericht, danke.
Warum macht man bei dem Radiator eigentlich so gut wie immer exhaust und nicht intake? Ich kühle dann den Radioator mit der heißen Luft vom ganzen System. Ich fände es irgendwie logischer wenn man unten und oben (Radiator) intake machen würde und hinten und seitlich dann exhaust.
Rizoma
Oben Intake ist nicht gut da man gegen den Kamineffekt arbeiten würde. Warme Luft steigt nun mal nach oben. Hast du eine Custom Wakü ist es egal wo die Radiatoren sitzen so lange du einen Punkt im Kreislauf hast der über der Pumpe sitzt wo sich die Luft sammeln kann. Bei AIO´s kannst du bei diesen Gehäuse die Seitenlüfter als Intake nutzen deswegen sind diese ja auch Reverse damit du die schöne Seite der Lüfter siehst. Der untere platz entfällt bei einer AIO, weil die Pumpen so gut wie immer im Block sitzen. Meines Wissens gibt es nur eine Hand voll AIO´s wo die Pumpe im Radiator sitzt die man dann unten einbauen könnte.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
