Monitors Practice Reviews
BenQ ZOWIE XL2566K Review – With TN panel and DyAc+ and the best motion clarity to the eSports top!
Today we’ll take a look at a monitor that is somehow different. Different in the sense of the target group. Different compared to most monitors on the market. The BenQ ZOWIE XL2566K was developed and designed specifically for eSports professionals. I really wanted to take a look at this monitor, because in terms of motion clarity, the XL2566K is supposed to be the measure of all things.
The XL2566K relies on TN technology, yes you don’t have to rub your eyes. A TN panel comes with both advantages and disadvantages. And, when testing an eSports monitor, don’t just dwell on the disadvantages of TN and let the advantages go under. For this reason, we’ll take a special look at motion performance today. We only look at the color accuracy with half an eye.
I’m aware that I’m coming around the corner quite late with my article, and there’s a reason for that. Because I am not a great like Tim from Hardware Unboxed or Optimum Tech. That’s why I’m even more pleased that BenQ believes that I’m one of the few people in the world who can realistically evaluate this monitor. You won’t find an article in this depth – with numbers/data/facts – in the German-speaking world in particular.
So much as an introduction in advance. As always, let’s look at the manufacturer’s data first. Of course, there is also the link to the homepage: Click here!
Technical data
Unfortunately, BenQ only offers HDMI 2.0, so you’re limited to 240 Hz via HDMI. If you want the full 360 Hz, you have to use the included DP cable. But PC users will probably prefer DisplayPort either way. Let’s take a look at the build quality and ergonomics of the XL2566K.
RedF
4,886 Kommentare 2,716 Likes
Das war mal ein interessanter Test. 1080 kommt mir zwar nicht auf den Tisch, aber schön zu sehen was es so gibt.
RedF
Fehlt noch ein von dir getestetes Samsung VA Gaming Panel : )
P
Phoenixxl
160 Kommentare 124 Likes
Vorteil:
Bei 1080p kann man auch mit Radeon Karten Raytracing benutzen.
Interessante Nische.
FritzHunter01
1,216 Kommentare 1,649 Likes
Ja, VA hatte ich noch gar nicht bei mir im Test. Ich personlich mag VA auch nicht sonderlich. Ich verzichte auf den höhren Kontrast und nehme lieber IPS. Oder am besten gleich OLED...
Aber, ich muss mir mal ein paar VA-Highend teile anschauen, da hast du definitiv Recht
SamSerious
21 Kommentare 7 Likes
Solche Monitore sind nicht nur für eSports interessant. Ich habe leider (nicht nur) beim Spielen öfters mit Kopfschmerzen zu kämpfen und da ist jedes Ruckeln oder Verschmieren bzw. Alles, was das Gucken anstrengend macht, ein potenzieller Grund, das Spiel zu beenden.
Darum habe ich mir vor ein paar Jahren den ASUS PG278qr geholt, der trotz TN Panel relativ teuer war, aber eben schnell ist und mir damit entspannteres Spielen ermöglicht. Da das Modell das vielleicht letzte mit Unterstützung für nVidias 3D Vision war, lässt sich bei Bedarf Strobelight für maximale Motion Clarity nutzen, dann allerdings mit unangenehmen PWM Effekten (logisch..).
Für das gleiche Geld hätte es andere Modelle mit erheblich höherer Bildqualität gegeben, aber damit wäre ich persönlich weniger glücklich geworden.
RedF
Habe selber einen Samsung VA ( C32HG70 ). Und bin doch sehr zufrieden damit, mir fehlen allerdings vergleiche die ich selber gesehen habe.
W
Wellenbrecher
49 Kommentare 43 Likes
Sehr interessanter Test, auch wenn der Monitor ein Nischeprodukt ist. Nur hier oder eventuell bei Prad kann man einen solchen Test finden. BenQ hat den Monitor optimiert und aus einem (guten) TN-Panel das Maximum rausgeholt. Hier sieht man, was für eine Rolle die verbaute Elektronik neben dem Panel eines Monitors spielt.
@RedF Du hast einen von den wenigen guten VA-Monitoren, von Samsungs G7 Reihe. Tim von Hardware Unboxed hat die 27 Zoll Variante als "Gaming Powehouse" bezeichnet. Die guten Samsung VAs haben auch keinen "black smearing", was ein Nachteil dieser Paneltechnik ist. Für mich persönlich kommt VA nicht in Frage, aber zum Zocken und Filmen/Serien schauen eine solide Option, auch wegen des hohen Konstrasts.
Nagah
115 Kommentare 94 Likes
@FritzHunter01
"Er kann dank DyAc+ jedem OLED-Monitor zeigen, wie Bildklarheit wirklich aussehen muss."
Werbephrase oder ist er wirklich klarer als z.B. ein 175Hz OLED?
RedF
Der 32" soll noch ne ganze ecke drauf legen.
Ich habe halt keine erfahrungen mit guten Monitoren und somit kein vergleich.
Mein lezter war ein 22" Samsung 16:10 und auf der Arbeit haben wir zwar 27" Benq, aber aus der Office Schublade.
Bin von dem Bild und den Farben (QLED) echt begeistert, es war der erste Monitor wo ich die Helligkeit runterdrehen musste ^^.
Ob die nachfolger das auch noch halten? Keine ahnung.
BlackFireHawk
109 Kommentare 115 Likes
Ich habe hier einen Samsung G7 Odyssey 1440p 240hz und einen Alienware DWF QD-Oled
Und obwohl der Samsung G7 sehr gut ist. Kein schmieren hat und extrem gute Reaktionszeiten und Farben hat. (laut Monitor unboxed immer noch in den Top 10 der LCDs)
Stinkt er gegen den QD-Oled einfach massiv ab was Farben, Reaktionszeit und flüssigkeit der Bilddarstellung angeht.
Die OLED 165hz sehen bedeutend flüssiger und smoother aus als die 240hz des VA panels.
Im direkten Vergleich nebeneinander schmiert der G7 einfach wie Sau.
Das ist aber etwas das man nur sieht wenn man beide nebeneinander stellt.. wer den OLED nicht kennt wird das nicht verstehen und nachvollziehen können und das Display des G7 super finden..
Was es ja auch ist im Vergleich zu anderen LCDs.. aber OLED ist noch Mal ne ganz andere Hausnummer
RedF
Ja habe schon einen neuen auf der Wunschliste ( bzw Sohnemann nerft mich, er will meinen haben ).
Aber ich weis noch nicht was für einer.
OLED 165Hz klingt ja schon verlockend : )
RedF
Wunsch Monitor müsste haben 32" oder größer, UHD oder ähnlich, OLED, >144Hz, leicht gebogen aber nicht zu sehr ( ja ich steh da drauf ) z.b. R1800.
BlackFireHawk
Dann kann ich dir den Alienware DWF ans Herz legen.. 165hz 3440x1440 @34zoll
Nur das 21:9 widescreen muss man mögen.. ich find's angenehn.. aber das ist wirklich ne Geschmacksfrage.. hin und wieder bekommt man ihn auch für unter 900€ mit Rabatten.
Aber Vorsicht das OLED macht süchtig.. selbst meine Frau die damit gar nix am Hut hat.. hat letzte Woche als wir im Saturn waren um den 15 Jahre alten Fernseher zu ersetzen auf OLED bestanden
RedF
Hmm der wäre ja etwa so hoch wie meiner, schmaler möchte ich es nicht haben.
VESA Mount geht?
BlackFireHawk
dafür hast du ca 10cm pro Seite mehr
VESA ist kein Problem
FritzHunter01
DyAc+ ist keine Werbephrase. Ein OLED könnte hier nur mit BFI mithalten. Bzw. müsste OLED mit 360 Hz oder mehr verfügbar sein!
RedF
Stehe kurz davor mir den Monitor zu kaufen 😁.
Eine Frage noch, es soll wegen der Pixelanordnung bei schriftlesbarkeit hapern, ist das wirklich so schlimm?
RedF
Hmm den Samsung G8 OLED gibt's teilweise günstiger, mir gefallen da nur die Anschlüsse nicht.
RedF
Hab mir den Samsung bestellt.
Bin gespannt 😁
Fritz Hunter
