Cooling Fans Reviews
be quiet! Silent Wings 4 (Pro) 120 mm Case Fan Review – When the name says it all | Part 1
The be quiet! Silent Wings 4 (Pro) 120 mm have already been extensively reviewed in the media, but today we finally have the long-awaited test. We chose the 120mm case fans as the first part, though we will follow up with the larger 140mm fans in a timely manner. In theory, there have already been press releases and information in wave-like bursts, but we can only really go into detail today. But in the meantime, we live with the fact that even left- and right-handed screws get their own NDAs. On separate days, of course, with the unpainted ones not allowed to be released until a week later. But well, joking aside, because now it’s getting serious.
The manufacturer offers both fan sizes as a standalone and a Pro version, whereby the Pro version is not only capable of everything the simpler version can do, but even quite a bit more in terms of maximum speeds. If you know the Pro version, then it is easy to conclude the other offered variants, which only differ in the available speed range. That’s why we only test the Pro version, but we have the advantage with our new metrics that you can also evaluate the other fans with these charts. For the sake of simplicity, I refer you to the recently published article on this subject.
Lüfter-Tests 2.0: Feedback, Messungen und neue Metriken für Gehäuse und Radiatoren am Beispiel des Phanteks T30
And what else? You have to be quiet! yes let, but they have consistently managed without lamp store. RGB is currently not even available for a surcharge, and that is a good thing. The hub (weight) and electronics (noise) are unencumbered and there is also no annoying illuminated ring that could negatively affect the radiator meter. The fan concentrates on what it is primarily supposed to do: realize good, but quiet ventilation. And that’s exactly what a Silent Wing 4 can do really well, even if I don’t want to spoil anything at this point. With prices between a bit under 25 and 32 Euros (RRP), you are already in the premium segment in terms of price, which sets the bar quite high.
The black frame is functional and simple, has a useful decoupling and for operation on the radiators even a quite passably functioning partitioning of the air flow, so that no pressure is lost. The rotor with its 9 moderately steeply pitched blades is not a great innovation in purely visual terms, nor is the 6-pole motor. But you don’t have to make the tried and tested worse by force, but you can optimize it in a targeted way. The fan once again relies on a good hydrodynamic plain bearing (FDB), which does exactly what it is supposed to. If you want to know all the technical details and the manufacturer’s point of view, I refer you to the specifications and the embedded documentation at the end of the page. It really says it all.
However, I will have various comments later on the engine noises, which occur independently of the bearing, up to the teeny tiny humming in some rpm ranges. The weight of 240 grams is not bad at all. The manufacturer specifies the thickness (installation depth) as 25 mm, which is even true.  The maximum gap of 1.5 between the rotor and frame is very good and the surface finish is definitely not objectionable. The power consumption turns out relatively high at full speeds with just under 4 watts for the fan at maximum speeds, but this is due to the high speeds. But I’ll get to all the details in a moment, because there’s an extra paragraph on that.
By the way, you also get a lot of accessories for the corners, so that the fans always find the right fit on radiators or in the case. This is commendable in every respect. Only cascading is not available, here you have to use the motherboard or a hub, which is a bit of a pity.
Silent Wings 4
Silent Wings Pro 4
For all those who still need the media-compliant buzzwords and features and would like to find out how easy it is to do all the cabling, I would simply recommend the Media Kit, where you can really find everything that has to do with the luminosity, optics, and condensing:
Press Briefing Silent Wings 4 - EN
On the next page you will first see how and what we test and why. Understanding the details is incredibly important in order to be able to objectively classify the results later. The differences between many models are more in the details and the best fan for all situations can hardly exist. There is a certain optimum in every situation and, of course, good all-rounders. But they usually have their price. However, if you are planning very specifically with 60 mm radiators, for example, you might be able to save money by choosing the best model for your intended use, which might not perform so well as a case fan. And vice versa, of course.
S
Schrauber1982
27 Kommentare 8 Likes
Hallo,
toller Test, auf der letzten Seite wird beim T30 aber 30 cm dicke angegeben, sollten wohl eher Millimeter sein.
Angenehmes Schwitzen, Grüße aus dem Ruhrpott bei 36 Grad
ssj3rd
225 Kommentare 156 Likes
Kommt den noch eine RGB Variante?
Ganz düster mag ich es inzwischen nicht mehr.
Oder sind das die Light Wings?
Pascal TM-Custom
1,122 Kommentare 1,361 Likes
wird es nicht in RGB geben. bq hat Momentan mit RGB nur die Light Wings im angebot
ssj3rd
Ok thx 🙏
Die LW sind ja auch absolute Top Teile.
F
FcryCola
81 Kommentare 6 Likes
Endlich wieder ein guter Lüfter ohne RGB.
Ich frage mich dennoch ob ich meine Arctic P12 tauschen sollte. Sitzen auf 3*360 GTS.
Wäre toll wenn ihr die P12 noch einmal neu messen könntet.
Grüße aus der Nähe von FFM im kühlen Wohnzimmer!
PS: danke für den Test der Nubert SP-200, meine 500er lassen mich im Urlaub seit gestern nicht mehr los :)
Ghoster52
1,460 Kommentare 1,123 Likes
Es verdient Anerkennung, wenn ein Hersteller seiner Linie treu bleibt und seine Lüffis weiterhin ohne RGB verkauft.
Nach dem Motto "Black is Beautiful" (y)
F
FcryCola
Absolut. Da hätte ich mich fast von der Optik der Kollegen aus Berlin überzeugen lassen aber DTS wird eben benötigt.
Nubert sollte aber unbedingt mal was im Marketing machen, deren Website sieht echt crazy aus und die Produktfotos sind total schlecht. In echt sehen die Boxen klasse aus und auch die Abdeckungen sind sehr schick.
p
passivecool
56 Kommentare 32 Likes
Es gibt auch den (meinen bevorzugten) Premimumanbieter aus Österreich bei dem bereits die Farbe Schwarz als Upgrade gilt...
Die Verkackbraunung von PCs hat dort Tradition 😝
Antwort 6 Likes
F
FcryCola
Das verstehe ich jetzt nicht?
F
FcryCola
Ich finde Noctua einfach zu teuer vorallem weil Igor ja im Test einen besseren Lüfter gefunden hat. Bin wirklich gespannt auf v2 der Tests mit Datenbank.
Atze Wellblech
110 Kommentare 21 Likes
Sehr lecker, vielen Dank. In der Farbe Weiss wären die Dinger geil :)
Nubert ist so konservativ, dass sie am liebsten noch die Homepage als BBS machen würden. Einwahl über Modem 😝🤦
F
FcryCola
Ja das kann ich mir gut vorstellen.
Es müssen erstmal alle aus dem Festnetz raus damit bei Nubert bestellt werden darf!
Da sieht man aber wirklich mal wie so etwas täuschen kann.
Gerne mehr hi-fi Tests vorallem für den Normalsterblichen! Dalia und Co sind ja toll aber nicht zu bezahlen.
Lagavulin
240 Kommentare 211 Likes
Oldschool finde ich gar nicht schlecht, wenn Qualität und Preis stimmen. Ich bin mit meinen nuPro X-6000 sehr zufrieden. Sind halt sehr neutral abgestimmt, das muss man mögen – ich mag es sehr. Und was Nubert aus den schlanken Boxen an druckvollem, trocknem Bass herauskitzelt, finde ich beeindruckend. Auf der Website habe ich auch alles gefunden, was mich interessiert (technische Daten, Manuals etc.). Aber wahrscheinlich bin ich mittlerweile nicht nur old, sondern auch ein wenig Oldschool.
F
FcryCola
Oldschool ist ja prinzipell super, auch wenn mein Jahrgang was anderes kennt.
Ich meinte auch eher im allgemeinen dass Marketing nicht zu unterschätzen ist und man dennoch von auf den 1-Blick posivitv überrrascht werden kann.
Die x-6000 müssen noch geiler sein, mir reicht aber schon die Power der 500er. Nur das Display ist bei den 6000er deutlich schicker.
B
BudSpencer
33 Kommentare 12 Likes
Endlich mal ein Test/Projekt ohne Alphacool ... Danke
igor'lLAB Community
