Little by little, the be quiet! range is being expanded new versions of popular coolers on the market, today it’s the turn of the Shadow Rock Slim. Whether the successor can hold its own in the middle class, you can read in the following article. By the way,Pure Rock Slim 2 and Silent Loop 2 were already on the testbench, now the Shadow Rock Slim 2 is coming.
We won’t dwell on appearances, the familiar black design is on display. As usual, a large product image is emblazoned on the front, the sides then provide information about the specifications and on the back there is again a brief description.
The accessories are packed strictly separated by socket in small bags and besides the mounting material only the most necessary things are included: A small tube of white thermal paste and another set of clamps for the optional second fan.
Assembly and installation
The mounting of the cooler has improved a lot in contrast to the predecessor in my opinion. Disappeared various small parts and mini wrenches and a separate backplate for AM4.
Now you simply use two brackets, which are screwed into the existing backplate of the mainboard and fix the cooler with two screws and a bracket in the middle.
Specifications
Since I’m writing this article before the official release, I can only add the product page after the fact. But here is the overview of the specifications available on the box:
Dimensions |
74 x 137 x 161 mm |
Weight (incl. fan) |
685g |
Material |
Aluminium |
Base |
Intel: 1200 / 2066 / 1150 / 1151 / 1155 / 2011-3 AMD: AM4 / AM3 |
TDP |
160 Watt |
Heatpipes |
4 / 6 |
Fan size |
135 x 135 x 22 |
Speed |
1400 RPM |
be quiet! Shadow Rock Slim 2 (BK032)
Auf Lager, Lieferung in 1-5 Werktagen | 40,00 €*Stand: 16.07.24 07:15 | |
Lagernd, Lieferung 1-2 WerktageStand: 16.07.24 07:38 | 44,13 €*Stand: 16.07.24 07:40 | |
lagernd, begrenzte Stückzahl | 44,50 €*Stand: 16.07.24 03:32 |
8 Antworten
