Cooling Reviews Watercooling
be quiet! Pure Loop 2 in test – sleek looks, smart technology, good performance
Even though the predecessor was not tested by us, we will not miss the newest member of the “Pure Loop” series. The manufacturer promises a better control via PWM of the decoupled pump and equips this complete water cooling with the new Pure Wings 3 high-speed fans.
The mostly black cardboard box already gives a good indication that the lighting here has been significantly reduced compared to the older Pure Loop 2 FX. The large product picture on the front confirms this assumption right away.
On the back, we are then informed about some core aspects of this AIO and can also read the specifications on the side.
Inside, we can expect the usual switch made of rough cardboard, which is supposed to protect the contents during transport. By the way, the small viewing window so that the product name can be read is very important!
The accessories include the usual mounting material, but also a few cable ties, 3 fan splitters and even a bottle of coolant. But don’t worry: It’s only meant as a replacement, should you ever need to refill it. Nevertheless, the Pure Loop 2 is already filled ex works.
Assembly and installation
With the modern AMD sockets, the existing backplate is reused and supplemented on the front with four screws, four spacers and two threaded brackets.
After thermal paste has been applied, the cooler base only needs to be fixed in place with two integrated screws before wiring can begin.
Specifications
Here is the overview of the technical details for the different versions of this watercooling, more information can be found on the product page at the manufacturer.
grimm
3,194 Kommentare 2,128 Likes
Bei mir tut eine Silent Loop 360mm den Dienst. Der Kühler sowie die Lüfter sehen identisch aus (und werden es auch sein). Die Einheit auf der CPU sieht etwas weniger wertig aus. Das macht dann wohl (plus RGB) den Preisunterschied. Wenn man die für um die 100/110,- kriegt, kann man getrost zugreifen.
p
pril
12 Kommentare 4 Likes
Ich verstehe das nicht ganz. Das ist wieder mal eine Alu-Kupfer Kombi, die nach ein paar Jahren garantiert nicht mehr zu gebrauchen ist.
Wieso wird das nicht erwähnt? Das ist ein Wegwerfprodukt.
Tim Kutzner
857 Kommentare 700 Likes
Weil es nicht der Realität entspricht, dank Korrosionsschutz. Und wir haben ja auch schon 6 Jahre Garantie bei "der üblichen Alu-Kupfer Kombi" gesehen, alles kein Problem.
p
pril
Nur eben hat dieses Produkt nicht 6 Jahre, sondern die Hälfte. Selbst wenn es 6 Jahre halten würde, grad im Hinblick auf Umweltschutz.
S
SpotNic
1,090 Kommentare 464 Likes
Und wenns 10 hält? Wer weiß das schon?
Ich habe ja bereits nicht nur einen Artikel zum Thema veröffentlich, u.a. auch detailliertere Betrachtungen zum nicht nichtkorrosivem Löten und den jeweilis benötigten Antikorossiva bei verschiedenen Metallen im Kreislauf. Das liegt alles am Inhalt, nicht den pauschalen Umständen.
Und für die puristische Kupfer-Fraktion:
Wenn Ihr wüsstet, was Euch so alles als Kupfer verkauft wird, Ihr würdet wohl heulen. Weiß- und Gelbmessing sind da noch die häufigsten Dinge, die Ich als genauso "verwerflich" betrachte. Hauptsache Lack drüber und ein tolles Edel-Brand-Logo drauf. Den beschissenen Zink sieht ja keiner :D
S
S.nase
1,440 Kommentare 486 Likes
Solange die Lamellen aus reinem Kupfer sind, bin ich schon zufrieden. Da stören mich Kanäle oder Vorkammern aus Messing im Radiator weniger. Vielleicht kannst du bei den kommenden Tests, ein kleines Stück von den LamellenBändern aus dem Radiator schneiden, und es unter deinen AnalyseLaser legen.
M
MD_Enigma
81 Kommentare 43 Likes
Nettes Produkt, aber ich denke die Zielgruppe ist verschwindend gering. Ich hab auf meinem 7800X3D den Pure Rock 2 und der ist schon fast überdimensioniert. Auf einem Non-X3D-Modell kann es Sinn machen, wer aber warum Perlen für die Säue? Damit bleiben eigentlich nur die Intel-Prozessoren, die kaum mehr einer kauft.
D
Deridex
2,224 Kommentare 858 Likes
Warum sollte die kaum mehe einer kaufen?
Ich finde auch die aktuellen Intel Prozessoren nicht schlecht. Nur mit den Spitzenmodellen habe ich meine Probleme.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
