The be quiet! Dark Power 13 1000 W uses a high-end FSP platform that offers maximum efficiency, absolutely silent operation, and ATX v3.0 and PCIe 5.0 compatibility. We will test the large version today, because there is also the 750 watt variant and one with 850 watts besides the 1000 watt model. Already the 850 Watt is completely sufficient for a GeForce RTX 4090 FE with 450 Watt BIOS and a maximum overclocked Intel Core i9-13900K. If you want to use the 600 watts of the graphics card, you should rather switch to the 1000 watt power supply we tested today. All in all, the new series without the Pro in its name is very interesting.
Reason enough for me to once again let my friend Aris from Hardwarebusters have his say (and picture) on our site, because he has not only tested this power supply intensively, but also officially certified it via his company Cybenetics. Since it is surely interesting for you as well, I will gladly offer him the platform to share his findings with you here from case to case.And don’t forget, his website and YouTube channel also offer real gems of really well-founded reviews!
The be quiet! Dark Power 13 1000W offers Titanium efficiency and absolutely silent operation. It is ATX v3.0 and PCIe 5.0 compatible and achieves peak performance in the demanding transient scenarios required by those standards. The Dark Power 13 line consists of three members with power ratings ranging from 750W to 1000W. FSP offers all Titanium-certified platforms that promise low noise performance. After all, this brand is known for its low-noise products, so I wonder why be quiet! hasn’t yet joined the Cybenetics program that recognizes low-noise products. A “quiet” oriented brand not supporting a “quiet” oriented certification is something I can’t explain.
The be quiet! Dark Power 13 1000W is sufficiently sized with a length of 175 mm, and I also believe that this is the right way to enable quiet operation. With compact power supplies, the cramped PCBs don’t allow for good airflow between the electronic components, so the fan has to spin quickly to dissipate the heat. I also agree with the lack of semi-passive operation when the fan is rotating at low speeds under light loads. The fan stop feature increases heat inside the PSU, so fan speed spikes can be annoying. Finally, the warranty is extended to ten years.
Technical data | |
Manufacturer (OEM): | FSP |
Max Power: | 1000W |
Cybenetics Efficiency: | Efficiency: [115V] Cybenetics Titanium (91-93%) |
80 Plus Efficiency: | Titanium |
Noise: | Cybenetics A++ (<15 dB[A]) |
Compliance: | ATX v3.0, EPS 2.92 |
Alternative Low Power Mode support: | Yes |
Power 12V: | 996 Watts on 4 rails |
Power 5V 3.3v: | 125 W |
Power 5VSB: | 15 W |
Cooling: | 35mm Fluid Dynamic Bearing Fan (BQ SIW3-13525-HF) |
Semi-Passive Operation: | No |
Modular Design: | Yes (Fully) |
High Power Connectors: | 2x EPS (2x cables), 4x PCIe 6 2 pin (2x cables), 1x PCIe 12 4 pin (600 W) |
Peripheral Connectors: | 13x SATA (4x cables), 2x 4-pin Molex (single cable) |
ATX/EPS Cable Length: | 600/700 mm |
Distance between SATA/Molex connectors: | 150 mm |
In-cable capacitors: | No |
Dimensions (W x H x D): | 150 mm x 85 mm x 170 mm |
Weight: | 2.45 kg (5.4 lb) |
Warranty: | 10 years |
Power Specifications
Rail | 3.3V | 5V | 12V1 | 12V2 | 12V3 | 12V4 | 5VSB | -12V | |
Max. Power | Amps | 25 | 25 | 32 | 32 | 40 | 40 | 3 | 0.5 |
Watts | 125 | 996 | 15 | 6 | |||||
Total Max. Power (W) | 1000 |
be quiet! Dark Power 13 750W ATX 3.0 (BN333)
![]() | Lagernd, Lieferung 1-2 WerktageStand: 16.07.24 07:42 | 184,84 €*Stand: 16.07.24 07:44 |
![]() | Auf Lager, Lieferzeit 1-2 Werktage | 188,99 €*Stand: 16.07.24 01:53 |
![]() | Online-Shop (Versand), Augsburg, Fellbach, Frankfurt, Heidelberg, Heilbronn, Karlsruhe, Lagerverkauf Magstadt, Ludwigsburg, Nürnberg, Pforzheim, Reutlingen, Ulm: auf LagerBöblingen , Esslingen, Freiburg, Mannheim, Stuttgart, Tübingen: auf Lager in 1-2 WerktagenStand: 16.07.24 06:53 | 189,00 €*Stand: 16.07.24 07:42 |
be quiet! Dark Power 13 850W ATX 3.0 (BN334)
![]() | Lagernd, Lieferung 1-2 WerktageStand: 16.07.24 07:42 | 222,06 €*Stand: 16.07.24 07:44 |
![]() | Auf Lager, sofort versandfertig Lieferzeit 1-2 Werktage | 224,90 €*Stand: 16.07.24 07:33 |
![]() | Auf Lager, sofort versandfertig Lieferzeit 1-2 Werktage | 224,90 €*Stand: 15.07.24 23:11 |
be quiet! Dark Power 13 1000W ATX 3.0 (BN335)
![]() | Lagernd, Lieferung 1-2 WerktageStand: 16.07.24 07:42 | 252,73 €*Stand: 16.07.24 07:44 |
![]() | lagernd: 25+ | 252,74 €*Stand: 16.07.24 07:38 |
![]() | sofort lieferbar | 257,69 €*Stand: 16.07.24 04:56 |
- 1 - Einführung, technische Daten und Testreport
- 2 - Unboxing, Kabel und Schutzschaltungen
- 3 - Teardown: Topologie, Komponenten, Verarbeitung
- 4 - Load Regulation, Ripple Suppression, Transient Resonse
- 5 - Hold-Up Time, Timings, Inrush-Current
- 6 - Average Efficiency and PF
- 7 - Betriebsgeräusch und Lüfter
- 8 - Zusammenfassung und Fazit
69 Antworten
