Headphones Reviews
Avantone Pro Planar Red Review – Excellent magnetostatic headphones for an acceptable price
Sure, in the price range between 400 and 500 euros there are many offers of open or semi-open systems. so why the Avantone Pro Planar Red and above all, why at this price? Of course, you can sink money into audio products (like cars or pets) with relish, and you’ll never get to the monetary end of unlimited possibilities unless your name is Croesus. And even if it may sound pretentious at first, for 500 Euros you get at most audiophile upper class, the real reference is still clearly above that. Really? Let’s see what we can do
One thing I want to say first, because I have to justify my judgement later: it is a purely private purchase, whose acoustic consequences I would like to share publicly, because it is worthwhile from my point of view. Of course, the 456 euros I paid for it online at the dealer is a lot of money, but of course you should always consider it in relation to the value. And that’s where it gets interesting, because the design doesn’t fit into the normal scheme at all. Neither is the exterior, by the way, but taste is secondary here for now.
What is a magnetostatic headphone?
The Avantone Pro Planar Red are headphones based on the magnetostatic principle, where a thin foil with an electrical conductor (“open coil”) is made to oscillate in a magnetic constant field provided by powerful push-pull permanent magnets (neodymium). If the electrical signal is now sent through the conductive paths running on the membrane surface, the foil moves back and forth between the magnets.
This special film is also much lighter than the speaker diaphragms of normal headphones and can thus theoretically also represent much finer nuances more vividly. The disadvantage is the weight of the necessary magnets – so the advantages of the huge transducer surface are not completely free. Nevertheless, not even 500 Euros for a magnetostat, as silly as it may sound to some, is a rather cheap affair. If you know what good it might do you. But first test, then we are wiser.
Scope of delivery and unboxing
In the somewhat bulky box you get the headphones weighing 480 grams, two connection cables, a canvas carrying bag and a kind of manual, which is actually none. German? Wrong! And the contents of the manual are also a bit sparse. Technical data and some self-congratulation, that was it, unfortunately. How and for what you can use the two enclosed cables, for example, the responsible buyer can then find out for himself by try & error. Occupational therapy.
You don’t learn that the two jacks on the headphones are both full stereo jacks and that you can actually get there easily with the one 3.5 mm jack cable. It doesn’t matter whether you plug it in on the right or the left. The Y-cable, which is also included, is only for connecting two such headphones at the same time for a human couple in love. This is quite useless, because the end pieces are not very long and the impedance of such a receiver is already quite low at 32 ohms. What’s really missing, however, and should really be a matter of course in this price range, is an adapter to the 6.3 mm jack found on better headphone amplifiers. In the picture I simply added them from my own stock.
Now let’s get to the externals, because they are really striking at first. The angular shape is somewhat due to the magnetostats, and the open principle with the grid of holes on the back of the shells. The color, ok, well. There are also this Headphones in black and purely optically everything gets a nice 1970s retro look. You can like that or not, the parts are stable in any case. Well, certain earmuffs in the industrial sector look quite similar, but so what? You take what you get and then you arrange. That was also possible with Abba back then, and once you have the thing on, you usually don’t see it.
What else? The fit is really perfect for larger heads, despite the headphones’ own high weight of almost half a kilogram. Mass full and caution with the headbanging, so that the heavy lump does not shoot off into the orbit. Sits well, but please only in a sitting position. The screw in the picture below should be tightened every now and then, even if the joint actually does well what it should. It is a simple but well working 2-axis solution with rotation and tilting movement.
The rest of the adjustment is taken care of by the headband made of imitation leather together with the elastic temple made of spring steel. It adjusts quickly, intuitively and really perfectly, so you could sit like that for hours without anything pressing. Actually, everyone whose head is still big enough can live with this, and once again you notice that no average Chinese measurements served as a template here, but the good old US-American large-capacity skull in 6XL This makes these headphones at least suitable for the EU, smaller women and children excluded. It won’t work because it can’t find its footing. Real hat sizes with a proud 64 in their passport, on the other hand, will be crassly pleased. Me, for example.
Let’s briefly return to the sockets for the connection cable. They are both parallel wired connectors and you can plug in whatever and wherever you want, it will always be right. Even the Y-cable could be plugged in on both sides, although it’s actually a bit pointless. Well, double is better and it looks groovier. Don’t. The cables are both textile covered and somewhat rigid. In addition, you should avoid touching them, otherwise you will have the perfect structure-borne sound in your middle ear faster than the person sitting next to you on the public transport can say pug.
He will have to put up with what the Planar Red, as an open headphone, reports to the environment. And that’s a lot. Up to 5 watts are listed in the data sheet, even though 250 mW should be enough according to the manufacturer. I once tortured myself on a trial basis, and the Beyerdynamic A20 grandiosely delivered me to the epicenter of the pain wave. You can do it, but you shouldn’t. Exactly for this purpose there is an explicit table in the manual, where there is nothing else, what is beneficial or detrimental to health to what extent and for how long. Level-fixed? But so much…
Which brings us to the, of course, rectangular, ultra-soft ear pads in grandma’s plush design. The dimensions are enormous and you get pretty much every eavesdropper loosely framed. They are also soft and unfortunately also tend to collect lint permanently. Ok, for that there are also lint rollers in well-stocked retail stores and gone is the coating. If need be, wide parcel tape will also help, that’s kind of my personal life hack for these crumb orgies. Works great and costs significantly less.
The parts are anchored by Velcro and can be easily removed or reattached. Below you can also see the openings above the magnetostats and on the right a few compensation openings for the mechanical sounding. But I’ll come to the sound later, because for now it’s all about the exterior and the interior.
The build quality is ok, but not top notch. Everything fits tightly, makes a valuable and durable impression and at least leaves no question marks. Of course, something like this is not premium, it lacks the more noble materials and a certain polish, but it is also not a manufacturing low blow. In the end we have a typical US product, which is at least as honest as a solid Weber grill, which doesn’t have small gap dimensions, but is actually made of one piece and indestructible and also does its job better than average. So the audio sample can only be good. Or is it? Let’s be surprised for once!
Avantone Planar Red
Music and More Storesiehe Shop445,00 €*Stand: 16.07.24 06:17
*Alle Preise inkl. gesetzl. MwSt zzgl. Versandkosten und ggf. Nachnahmegebühren, wenn nicht anders beschriebenmit freundlicher Unterstützung von geizhals.de
b
butch111
57 Kommentare 19 Likes
Ich hab DAC/Verstärkerseitig grade 2 aktuelle Sets ausm 4 stelligen Bereich da und verschiedene Kopfhörer - Leistung also satt. Ich würde mich schon schwer wundern wenn dieser Avatone wirklich ne Empfehlung ist.
Hatte in den letzten Jahren alles mögliche an richtig teurem Sch... hier.....auch verschiedene Magnetostaten. Soeben liegt hier u.a. ein Hifiman Ananda rum und versucht zu überzeugen...vergebens)
Ganz ehrlich - kauft in dem Bereich von 400 Euro lieber safe nen Sennheiser HD660S mit gematchten Chassis....lasst den 10 Stunden einspielen, gönnt dem n anständigen DAC und einen Versärker mit ausreichend Leistung (für mich ist im bezahlbaren Bereich mehr Potenzial im DAC als im KHV)
Damit seid Ihr ganz weit oben....denn die neueste Version des 6ers ist schon eher Richtung HD800S abgestimmt....nur stressfreier.
Und wenn Ihr mit dem Gamingstuhl mal übers Kopfhörerkabel fahrt (symmetrisch und unsymmetrisch liegt bei - allerdings kein XLR ,aber mit bischen basteln oder nem Adapter möglich) dann kostet das Kabel UVP 9,90 Euro (statt 300 beim HD800S)
Ich bin mitlerweile so weit das ich richtig teure Kopfhörer gerne meide - grenzt eh fast an Betrug - und bin nach langer hoch fünfstelliger Reise glücklich mit nem effen HD660S.
Wichtig: Die älteren Versionen des 6ers sind NICHT vergleichbar.
Wichtig2: Jeder hört anders!
Wichtig3: my 2 cents!
10,468 Kommentare 19,597 Likes
Ich höre auch oft gern mal vier- gegen dreistellig bei guten Kopfhörern und wundere mich jedes Mal über die ganzen Mythen, die den Preis rechtfertigen sollen. Ja, ein Elektrostat mit speziellem Verstärker hat was ganz Eigenes, das gebe ich gern zu, nur muss er auch zu Stimmung und Musik passen. STAX hin und her, Güttler samt Bachtrompete geht für mich damit gar nicht. Ich bekomme Kopfschmerzen, weil die Wiedergabe meilenweit neben dem Original landet. Alles viel too much, wenn man das noch in echter Hörerfahrung aus dem realen Leben hat. Was mich an dem Avantone am Ende doch dazu bewogen hat, ihn zu behalten, ist die Kombination aus Frechheit und Leichtigkeit. Das passt nicht für alle Genres, aber KH wie der Sennheiser haben keinen eigenen Charakter und sind kreuzbrav. Sie spielen noch relativ ehrlich, das muss man neidlos anerkennen, aber sie wecken eben damit auch null Emotionen. Und genau das gehört für mich mit einfach dazu.
Antwort 4 Likes
b
butch111
Ja - voll Deiner Meinung.......Ich seh bei Dir n Denon 7200 oder 9200 aufm Tisch...genialer Hörer (besonders der wesentlich höher auflösende 9200)...aber zock ma mit den Highendern.........also für mich rasiert der HD660S so ziehmlich alles in Sachen Ortung - kann quasi den Monitor aus machen ;-)
Hab daran zzt Topping D90/A90 Kombo am Senni - in ner Stunde kommt der RME ADI 2 DAC V2 ....mal sehen was der besser macht als der Vorgänger.
Denon 7200, der 9200 ist mir nicht spaßig genug. Der 7200 ist eigentlich Badwanne pur, löst aber trotzdem wirklich gut auf. Jazz geht mit dem Teil am besten, Gaming übrigens auch. Da ist der Bass-Boom und Höhen-Boost bestens aufgehoben. Ernsthafte Musik geht damit echt nicht oder nicht wirklich. Die T1 und T5 der Gen. 2 leihe ich mir ab und an für solche Tests mal beim Nachbarn, die aktuelle 3. Generation ist komplett vermurkst, ich habe die Dinger zurückgeschickt. Das ist fast schon eine Beleidigung. Keine Ahnung, warum diese Abstimmung so sein muss.
Megaone
1,822 Kommentare 1,718 Likes
Seh ich prinzipiell ähnlich. Nach Beyer T90 und HD700 sowie AKG 701 bin ich nun bei Sennheiser HD 58x Hifimann HE4xx. Beide zu Peanutspreisen bei Massdrop. Auch bin ich ehrlicherweise immer wieder erstaunt was mein Senni 560 HD Ovation 2 alles drauf hat. Allerdings fällt er langsam auseinander. Was mir ebenfalls gut gefällt ist der Beyer 990 pro. Zwar kein High-Ender, macht aber wirklich spaß. Der 660er steht als nächstes auf der Liste. Allerdings guter DAC und KHV sind Pflicht.
s
scotch
154 Kommentare 105 Likes
Ich habe den T1 3. Gen. sowie den T1 2. Gen. (An einem RME ADI-2 FS) Beide gefallen mir extrem gut, finde die 3. Generation aber noch einen tick besser.
Wieso findest du die 3. gen vermurkst?
C
CortexFriend
6 Kommentare 0 Likes
Da bin ich aber froh, dass ich nicht der einzige bin, der seinen 560 HD Ovation hegt und pflegt und immer wieder zusammenbaut (neues Kopfband, neue Polster, neues Kabel).
Manchmal frage ich mich, wo 20 Jahre Entwicklungszeit geblieben sind...
Diverse DTs (DT660, 880 und 990) mussten wieder gehen, bleiben durfte nur der AKG701. Der ist am SPL Phonitor eine analytische Macht, aber die ist manchmal einfach zu stark. Und da kommt dann dann der Ovation ins Spiel, wenn es zu grausam wird.
Typische Andienung an den Mainstream. Viel zu basslastig und oben raus die Sibilanten können schon mal zu sehr zischen und die Ausblasgeräusche von Bläsern zerren an den Neven (sogar am A20). Der Superhochton ist dann hingegen fast ganz weg. Dazwischen ist alles sehr warm, fast zu warm, aber irgendwie auch arg verhangen und leicht matschig. Mir fehlt die Luftigkeit und Leichtigkeit der Vorgänger. 500 Euro, naja. Aber für 1000 erwarte ich einfach mehr.
Der AKG ist eine extrem ehrliche Haut, auch nicht jedermans Geschmack. Man hört alle Unreinheiten ziemlich deutlich. Zum Abmischen sicher mega :D
Megaone
Konnte vor einem Jahr einen ungebrauchten und Originalverpackten ergattern. ( nach 10 Jahren suchen). Mein alter 560er aus 92 hängt am PC zum zocken. Der erste, der ihn klanglich distanziert hat, war der HD 700. War mir aber zu empfindlich und die Ersatzteile zu teuer. Der Hifiman ist insgesamt der Ok, aber nicht der erhoffte Überflieger. Spannend ist der 58xer. Der macht Bässe, die sind nicht aus der Kopfhörerwelt. Der AKG 701 ist ein Top hörer, mir aber zu langweilig. Mal schauen, ob ich den Massdrop 6xx oder den 660S die Tage bestelle.
b
butch111
Massdrop 6xx und 660S bitte nicht in einen Topf werfen!....der XX ist angeblich ein 650er und der 660S soll die Treiber vom 700er haben. (soll!)
Megaone
Mag sein, aber die Frequenzmessungen sehen sehr ähnlich aus. Allgemein wird übrigen der Sundara als das bessere Produkt gesehen. (Ich kann es nicht beurteilen, aber die Meinungen gehen ja in dem Bereich immer sehr auseinander). Die Frage, ob der doppelte Preis des 660s gerechtfertigt ist erscheint mir zumindest nicht eindeutig beantwortbar. Aber vielleicht kenn ja jemand beide?
b
butch111
Frequenzmessungen sagen extrem wenig über den Klang aus. Such Dir 2 Kopfhörer mit annähernd gleicher Kurve und das kann ein Unterschied wie Tag und Nacht sein. Das Problem, man sehnt sich nach Messbarkeit - aber sone Kurve gibts einfach nicht her.
Auflösung, Bühne und Tiefenstaffelung kann man auch nicht messen. :D
Megaone
Stimmt, trotzdem ist die Frage ob der Preisunterschied schlüssig ist? Ich bin mir da im Moment nicht klar.
b
butch111
Ist die Frage ob Dir ein hochauflösenderer Kopfhörer zusagt. Was helfen Dir 200Euro im Portemonaie wenn der Hörer nichts mit nem HD700 zu tuen hat der Dir gefiel?
Musste aber selber rausfinden.....ich bin eh abgehärtet durch meine Kopfhörerreise - ich finde 400€ fürn HD660S geschenkt....aber das hätte ich vor 5 Jahren sehr wahrscheinlich auch komplett anders gesehen.
BTW - Der RME ADI2DAC holt das Maximum aus dem Hörer raus.....meinen hochgelobten Topping Krempel kann ich wieder abstossen nach der heutigen Session.
never ending story.....
Exorbitantist
Nicht uninteressant, denn von dem Hersteller habe ich bislang noch nichts gehört. Wirklich gute orthodynamische Kopfhörer kennt man im wesentlichen nur von Hifiman. In jüngerer Zeit auch von Final in Form des D8000 Pro.
Optisch finde ich das Modell in Ordnung, quasi eine gelungene Mischung aus Stax und den erwähnten Hifiman, mit dem Vorteil von frei beweglichen Ohrmuscheln - letztere hat man bei Hifiman unterhalb der Arya nämlich leider nicht. Die Verarbeitung scheint laut dem Artikel deren Niveau dabei nicht zu überbieten, was wiederum etwas Schade ist, im Austausch gegen hinreichend guten Klang aber noch akzeptabel in der Preisklasse.
Man findet zu dem Modell sehr wenig Testberichte in der Hifi Community. Laut einem Vergleich mit den Hifiman Sundara, sollten sie grob auf deren Level liegen, bei signifikant mehr Gewicht. Allerdings bekommt man die Sundara auch schon für 350 €, sodass bei tatsächlich ähnlicher Performance der Vergleichssieger klar wäre. Gegen die (deutlich) teureren Ananda oder die eingestellten HE560 dürfte dagegen eher kein Land zu sehen sein.
Persönlich würde meine Empfehlung Sub 500 € Sennheiser HD600 oder Audio Technica ATH-R70x lauten. Oder wenn es planar sein soll eben die Hifiman Sundara.
1,692 Kommentare 1,029 Likes
Zunächst Mal: Danke für den Test und Bericht! Jetzt bin ich zwar auch ein (im Prinzip) Audiophiler, aber einer muss auch den Plebejer machen, und warum nicht ich? Also, hier die Frage an Igor und das Forum: Welche(r) Kopfhörer in der € 50 (und darunter) Klasse ist noch am ehesten erträglich? In meinem Fall suche ich nach einem offenen, aber die Ohrmuscheln umschließenden Design für auch eher großen Kopf; klanglich etwas mit dem man so Querbeet, durch Kraut und Rüben Musik hören kann ohne daß einem dabei gruselt. Empfehlungen?
s
scotch
Günstige Kopfhörer die trotzdem zumindest gut bewertet sind findet man vom Superlux.
Mal bei Thomann schauen.
felgi
4 Kommentare 0 Likes
So, genug Jahre nur gelurkt, die anmeldung war längst überfällig... 😜
Ich war überrascht, habe seit einer Woche einen Fostex T50RP hier liegen, mit Dekoni-Pads drauf gefällt der mir sogar fast besser als die HiFiMANS die ich im Regal habe. Schön linear aber knackig. Absolut umwerfend (im negativen Sinne) sind hier aber der wirklich billige Kopfbügel und die deutlich zu kleinen Stock-Pads, die in diesem Internetz oft gefundene Aussage des 'world's most modded headphone' überrascht mich an der Stelle nicht. *räusper*
Von denen habe ich auch welche herumliegen, behalten habe ich den beyerdynamic-Klon HD 330, damit kann man in der Preisklasse absolut nichts falsch machen. Wem die Pads auf Dauer zu matschig sind, einfach bei beyerdynamic im Ersatzteilshop umsehen, man bekommt quasi alle Originalpads jeder Preisklasse draufgezogen und hat schnell mit wenig Aufwand und geringem Budget einen spaßigen, warmen Hörer.
Follow Igor:
