Audio Audio/Peripherals Headsets Reviews
Austrian Audio PG16 Pro Gaming Headset Review – A solid start, but there is still a lot to learn!
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
With the PG16, the young company Austrian Audio enters the world of gaming headsets and sets high goals for itself. Although the headphone part of the headset is well done, some solutions are implemented rather frustratingly. Why the PG16 could be interesting for lefties, you can read in the review.
Yet another brand that most readers have never heard of? At the same time, the Austrian Audio brand actually emerges from a fairly well-known company. Namely, AKG Acoustics GmbH, which was more or less dissolved after the parent company Harman was taken over by the Samsung Group. However, since the core team of the former AKG GmbH wanted to continue to develop and distribute high-quality solutions in the field of headphones and microphones, the company Austrian Audio was founded without further ado.
After establishing themselves on the market with some rock-solid headphones, they now want to shake up the gaming industry with the PG16 headset.
Technical data
The technical data and features of the headset as well as the description read very well. As always, I have a table ready and then list the core features of the headset.
The following features are supposed to be offered by the PG16 and of course I will have a close look at them.
High precision sound
Thanks to the proprietary Hi-X technology (High Excursion) drivers, the sound is supposed to be particularly high-resolution and rich in detail.
Spatial Sound Card 7.1
A software for simulating a Spatial Sound Card with 7.1 effects from a third-party provider should offer the best possible listening experience and must be installed.
Memory foam ear pads
The wearing comfort is supposed to be particularly pleasant due to the high-quality ear pads.
Tilt-to-mute
The omnidirectional microphone, which is advertised as “high-end”, has a “tilt-to-mute” function and can thus be conveniently muted by folding the microphone boom upwards.
Sustainability
The wearing parts ear pads and cable are removable and replaceable, which should make the headset particularly durable, hygienic and sustainable.
Construction
Thanks to the sturdy metal hinges on the ear cups, the design can be folded and conveniently stored in the included carrying bag.
Compatibility
The headset is compatible with PC, Mac, PS4, PS5, Xbox (controller with TRRS jack provided) and also carries the TeamSpeak certificate.
RedF
4,879 Kommentare 2,708 Likes
Gefällt mir das Headset.
Aber Kabel rechts und zu kurz geht ja garnicht.
Kann mir garnicht vorstellen wie einem in der etwicklung solche patzer passieren können.
Ghoster52
1,455 Kommentare 1,121 Likes
Wünschenswert wäre mal noch eine Bemaßung der Polster (Größe innen & außen, findet man leider viel zu selten)
Ich nutze zu gern der Individualität wegen Custom-Pads von Drittanbieter (Klangoptimierung).
Kabel rechts kann auch vorteilhaft sein bei der Kürze (mein PC steht rechts). ;)
Im Fluss gibt es Kabel-Alternativen bzw. Verlängerungen.
Das er "klanglich" gut ankommt wundert mich nicht, die ehemaligen AKG Mitarbeiter wissen wie man KH baut... (y)
RedF
Ja für 130€ kann man aber schon ein langes Kabel erwarten.
Ghoster52
Da hast Du allerdings Recht, aber ich nutze KH sehr gern mobil und ich hasse lange und fest verbaute Kabel.
Wenn möglich, bekommen meine KH da ein Update (Klinkenbuchse), aber ich bin da eher die Ausnahme (Nerd),
weil die letzten KH Eigenbau waren.... :LOL:
Für mich ist Kabel & Polster wechselbar einfach Pflicht.
RedF
Beim MMX 300 war ein langes und ein kurzes Kabel mit bei. Das ist mir beinahe etwas zu klein -_- habe wohl einen großen Kopf.
Llares
71 Kommentare 35 Likes
Hm, die meisten Rechner stehen rechts (was mich persönlich nervt). von daher macht es schon Sinn, dass Kabel rechts heraus zu führen. Bei meinen Kopfhörern muss ich das Kabel entweder hinter dem Rücken her führen, so dass ich dann mit dem Stuhl drüber fahre, oder unter den Armen durch, was auch nervt. Da ist ein Kabel, was mit rechts über die Schulter läuft echt lieber.
Alexander Brose
836 Kommentare 598 Likes
Mein PC steht auch rechts neben mir auf dem Schreibtisch. Und das Kabel geht genau über den rechten Arm hinter den PC und hängt die ganze Zeit in der Maus. Um es über die Schulter und evtl. rechts um den PC zu legen, ist es mit 1,4m einfach zu kurz. Ich hatte es für den Testzeitraum die meiste Zeit mit Klettband am Deckel des Gehäuses fixiert, damit es nicht ständig nervt.
Grüße!
RedF
Ok hab ne Externe Soundkarte, die steht halt links.
Ghoster52
Oder man macht es wie bei OneOdio Pro 10 / 30 / 50 usw. beidseitig anschließbar... (inkl. 2 Kabel 1,2 & 2 Meter) (y)
A
Art
51 Kommentare 10 Likes
Dass AKG von Harman übernommen wurde, habe ich ja noch (mit Bedauern) mitbekommen - dass diese wiederum von Samsung geschluckt wurden nicht mehr.
Nach meinem letzten Hörtest muss ich feststellen, dass ich wohl keine neuen Kopfhöhrer mehr kaufen werde, sondern eher Hörgeräte ;)
Den guten K701 mit AKG Gedächnisnoppen aus der 'Made in Austria' Ära habe ich in der Sammlung.
Beim Gaming bleibt's beim Beyerdynamics Custom One Pro mit Velour Polstern plus V-Moda Boom Pro Mic.
s
swatcher1
17 Kommentare 0 Likes
Bei dem Preis keine Kabelfernbedienung oder andere Möglichkeit die Lautstärke direkt am Device zu regeln gehört doch recht deutlich auf die Contra-Liste, findet Ihr nicht? :)
10,476 Kommentare 19,611 Likes
Wer nutzt das im Zeitalter von Multimedia-Tasten noch? Sollbruchstelle :)
s
swatcher1
Easy: Ich und quasi alle Zockerkollegen in meinem Umfeld. Oo
"Kabelfernbedienung" ist halt als Synonym zu betrachten:
Viele haben die - von mir als fehlend deklarierte Steuerung für Lautstärke - direkt am Headset selbst.
Alexander Brose
