3D-Printer Picture stories Practice Reviews
Anycubic Kobra 3 ACE Pro 3D Printer Review – Good multi-material alternative with Klipper or worse copy?
Here and there you see teasers of multi-material systems from other providers, so Prusa and Bambu Lab have to make some room in the niche. Anycubic are now the first on the market and are launching their “ACE Pro” together with a new printer. And it remains to be seen whether the top dogs need to be afraid of the new competitors or whether the whole thing isn’t really terrible for the end customer.
The Kobra 3 and ACE are delivered in a large cardboard box, which – much to the delight of the parcel deliverers – is provided with grip holes on the side.
When you open the lid, all kinds of foil and foam are revealed.
The best thing to do is to find as large and free an area as possible to unpack the large cube.
You can then work your way forward piece by piece.
Put the ACE to one side for now, we’ll get to that later.
Stow all the foam back in the box, it might come in handy again.
And then we can take a first look at the 3D printer named after a snake, visually they don’t have much in common.
The printer comes with various attachments, tools and all kinds of small parts, which you can see here.
Here is an overview of the key technical data, further information can be found on the shops’s product page.
p
pinkymee
130 Kommentare 157 Likes
Super Test. Danke. Es ist schon bitter, wenn der Drucker nach dem zweiten Drittel durch Kollision oder Ablösung abbricht. Das Filament gibts bei dem Drucker nicht umsonst, oder? Und noch ne andere Frage, warum erstellt er überhaupt einen Prime Tower? Kann er den Müll vom Farbwechsel nicht einfach ins Loch abstreifen?
In dem Stadium macht der Drucker einen gemischten Eindruck. Hier scheint man als Kunde noch das Versuchskaninchen zu sein ;) Mit nem LKW voller Free-Filament, wäre das vermutlich für Viele sogar gangbar und weniger frustrierend :D
Tim Kutzner
893 Kommentare 734 Likes
Selber Grund wieso Bambu Lab und Prusa es auch tun, damit der Druck in der Nozzle nach dem Farb- oder Extruderwechsel passt.
Deswegen ist es auch ein Prime Tower und kein Purge Tower, denn um den Müll geht es nicht.
Den kachelt man ja schon vorher seitlich weg :D
p
pinkymee
@Tim Kutzner Aber warum bollert dann der Druckkopf den Tower weg? Schlecht programmiert? Noch zu unausgereift?
Ich versteh es noch nicht ganz ;)
Tim Kutzner
Schön wäre es, das habe ich selbst gekauft
Ungenauigkeiten im Bewegungssystem und/oder schlechtes Auto-Bed-Leveling
p
pinkymee
aaah okay, danke :) eigentlich schade ums Produkt, denn wenn er mal druckt, schaut es richtig gut aus, bis auf die feinen Fäden
S
SpotNic
1,130 Kommentare 491 Likes
und die Lücken im Druckbild und das Schriftbild auf den Testdrucken. Da gehen wieder einige Stunden Einstellarbeit drauf bis man wirklich gute Druckergebnisse hat.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
