CPU Latest news System
AMD Ryzen 6000 ‘Rembrandt’ APUs said to already rely on Zen 3+ in 6nm and up to 12 RDNA 2 GPU compute units
There is some movement in the leaker scene again and so it is not surprising that also various information about AMD’s next GPU leaks out. So now we could also enjoy new details about AMD’s next APU lineup, the Ryzen 6000 “Rembrandt”, published by ExecutableFix, a reputable leaker. In fact, according to his latest tweet, it looks like the next APU generation is coming this year or in the begin of 2022. The new Ryzen APUs will be the one and only family that could feature the mysterious AMD Zen 3+ core architecture.
According to the new details, AMD’s next-gen Rembrandt Ryzen APUs will thus be based on the Zen 3+ and RDNA 2 GPU cores. This isn’t just any Zen 3 / RDNA 2 cores though, as the roadmap also mentions that the chips will be based on a 6nm node. AMD is expected to retain TSMC manufacturing for the Rembrandt CPUs and so the improved process could be expected to deliver around 20% higher transistor density with lower power consumption.
AMD’s Zen 3+ is said to be a slight evolution of the existing Zen 3 core architecture, and it will likely bring a number of process optimizations and clock speed improvements, even though the actual underlying design is expected to remain the same. The use of Zen3+ was originally rumored for a desktop release at the end of the year, but new reports now suggest that this has been scrapped in favor of a simple refresh, similar to the Ryzen 3000XT (Zen 2) CPUs, for example. Update instead of launch.
AMD will also be using its RDNA 2-based Navi 2 GPUs in the Rembrandt Ryzen APUs this time around. The Ryzen 6000 lineup should then offer up to 12 compute units. That means you could see up to 768 stream processors, which would be a 50% jump over Cezanne with only 512 Vega stream processors. In addition to the new GPU architecture, it is also expected that the graphics part of the APUs will have very high clock speeds, as we already know from desktop graphics cards. AMD is also expected to continue RDNA 2 graphics later in the Zen 4-based Phoenix APUs, and only move to the next RDNA architecture starting with the Zen 5-based Strix Point APUs.
In addition to the core technologies, AMD is also said to be deploying its CVML (Compute Vision & Machine Learning) system on the Rembrandt chips to achieve better AI capabilities that would directly target Intel’s future AI-enabled chips in the desktop and notebook segments. Other interesting features of AMD’s Rembrandt APUs will be PCIe Gen 4 support and LPDDR5/DDR5 memory support. The Rembrandt APUs will offer up to DDR5-5200 memory support, 20 PCIe Gen 4 lanes and two USB 4 ports (40 Gbps).
AMD’s Ryzen 6000 APUs could thus also be the first APU family to use the new AM5 socket. Because only this new socket will allow full support for features like DDR5 memory support. The Rembrandt desktop APUs are scheduled to launch in early 2022, so the AM5 platform should also be available by that time. So let’s be surprised, because AMD could also cleverly counter Alder Lake-S with this, at least in the graphics area.
Case39
2,550 Kommentare 965 Likes
Moin. Dachte ich mir schon fast, das es ZEN3+ nicht auf den Desktop schafft. Ein einfacher Refresh vor ZEN 4, sollte es ebenfalls machen.
Lohnt sich eigentlich auch nicht. AMD wird wohl auch erst mal schauen, was Alder Lake-.S kann, bzw. auch nicht. Der Rest erledigt sich dann von selbst. Man kann, muss aber nicht. :D
Antwort 4 Likes
konkretor
312 Kommentare 321 Likes
Bin sehr auf die GPU Performance gespannt
D
Denniss
1,580 Kommentare 586 Likes
wird wohl erstmal nur im Schlepptop verbaut werden. Wenn die Grafik einen Leistungsschub bekommt dann können sich die OEMs separate Grafik der Einsteigerklasse weglassen.
S
Stele77
10 Kommentare 2 Likes
Dank dir Igor für die Infos!
Bin da trotzdem, wenn es so kommen sollte, etwas enttäuscht. Zen4 scheint da ja noch sehr weit weg zu sein.
Wenn AMD nun wenigstens die Zen3 Ryzen 3 und einen 65W non-X 5er für ca. 220€ mal endlich rausbringen würde, wäre Ich schon happy.
Die X-SKUs sind nun ja fast durchgängig zu UVP oder nahe dran verfügbar.
Hätte Ich nicht schon ein AM4 Board, würden die i3/i5er ziemlich attraktiv aussehen..
HerrRossi
6,821 Kommentare 2,256 Likes
Toll, wieder neue APUs, die der Endkunde eigentlich nicht kaufen darf und nur als tray zu horrenden Preisen bekommt.
LurkingInShadows
1,386 Kommentare 584 Likes
Is bei Notebooks wie bei Handys, kauf gefälligst neu bevor du reparierst :p
Wie jetzt?
61 Kommentare 48 Likes
AMD ist aktuell in einer sehr komfortablen Position. Wenn Alder Lake doch der (eigentlich nicht erwartetete) große Wurf werden sollte kann man das eventuell mit einem schnöden refresh a la XT kontern, muss aber jetzt nicht in "Vorleistung" gehen und zwingend noch Zen3+ auf AM4 bringen.
C
Capsaicin
211 Kommentare 92 Likes
Danke für den Artikel! Ich bin ja mal super gespannt, was da so kommt, und wie RDNA 2 sich in Mobile schlägt!
Das habe ich bisher anders verstanden. RDNA 2 soll in Zen 4-Desktop-CPUs zum Einsatz, also vermutlich im I/O-Die. AMD hat, seit sie Ryzen rausgebracht haben, seine IP ziemlich strikt an die vorgesehene Fertigung gekoppelt (mit der einzigen Ausnahme Vega in 14 und 7nm, weil RDNA und CDNA noch nicht fertig waren). Fertigungssprünge innerhalb einer Architektur gab es nur, wenn designkompatibel (14nm->12nm und eben 7nm->6nm). Das passt dann auch wieder, wenn RDNA 2 bei Zen 4 in einem hypothetischen 6- oder 7nm-I/O-DIe steckt. Zen 4-APUs werden also imho in 5nm mit RDNA 3 antreten.
LurkingInShadows
Gut Intel war ja lang genug in dieser Position, mit AMD am hinterherhecheln.
1,698 Kommentare 1,031 Likes
Nun immer her damit! Scheinbar hat TSMC wohl Kapazität auf N6, und das SoC für SONY's PS5 Refresh soll ja wohl auch auf N6 gefabbed werden. TSMC bietet N6 seit 2019/2020 an, und empfiehlt den Umstieg von N7 auch weil der Node Wechsel kein komplettes Neudesign braucht. Ein (sehr kleiner) Wermutstropfen ist daß ( laut TSMC) N6 keine höhere Perf/W Effizienz als N7 hat, dafür aber immer noch mehr dies pro Wafer ergibt. Außerdem ist dies ja Jammern auf hohem Niveau. Eine 6 oder 8 Core Rembrandt APU wär ideal für mein HTPC Projekt.
LeovonBastler
42 Kommentare 13 Likes
Vega war allerdings nicht die ganze Architektur, das ist GCN und Vega ist die Version 5.x von GCN. Allerdings muss die Architektur immer angepasst werden auf die Vorteile und Tücken der Lithografie (Was AMD ziemlich sicher tat, Vega 7nm ist 5.1, während Vega 14nm 5.0, die müssten also etwas gemacht haben). Die grundsätzliche Architektur, wie es Sachen verarbeitet wird allerdings selten geändert, schätze ich mal. AMD/ATI machte das aber schon immer bei deren Grafikkarten, ist also nix Neues. Nvidia allerdings... Bei denen ist das vergleichsweise selten der Fall.
Maxwell auf 28nm -> Pascal 16nm ist die Ausnahme, wie auch Tesla 2.0, wo die GT200 von 65nm auf 55nm in Form von GT200B umgestiegen ist.
Man kann aber nicht einfach mal so eben eine Architektur auf eine andere Struktur als die vorgesehene porten. Da müssen Optimierungen getroffen werden, damit man keinen weiteren Fermi-Desaster bekommt (Dort haben die nichtmal geported, sie haben anscheinend einfach nicht für den 40nm Prozess optimiert. Sie hatten generell Probleme der Lithografie, da selbst kleine Chips (100-200mm^2) schreckliche Ausbeute hatten... Und dann kam Fermi mit 529 mm^2).
Mehr zum Fermi-Desaster: https://semiaccurate.com/2010/02/17/nvidias-fermigtx480-broken-and-unfixable/
C
Capsaicin
Seh ich genauso :)
Deswegen sag' ich ja, seit 2017 hat AMD nur Vega, mangels Alternative, geshrinkt. Das werden sie mMn auch so schnell nicht ändern. Ich meine auch, sie hätten mal gesagt, dass sie vorhaben quasi die "passende Architektur für den passenden Fertigungsprozess" zu designen (anders, als Intel das jetzt macht).
Nach dem, was ich so gelesen habe, wird es immer wichtiger mehr aus dem Design rauszuholen, indem man für einen bestimmten Prozess optimiert, und sogar den Prozess an das Design anpasst, also die Zusammenarbeit zwischen Foundry und Chipdesignern intensiviert. Bei den stark steigenden Preisen pro Chipdesign wundert mich es auch nicht, dass man versucht alles raus zu holen, was geht.
Sprich, es wird von der Fertigungstechnologie abhängen, welche Architektur wir auf welchem Chip sehen, und welcher Chip wann (frühestens) auf den Markt kommt.
R
Ryzen
55 Kommentare 8 Likes
Die beste APU ist der Ryzen 3 3400G, finde ich. Hat ja auch fast 2 Floating Point Operations Per Second ^^
S
Schakar
177 Kommentare 90 Likes
Wenn die Preise noch lange so bleiben (und die Verfügbarkeit) wird meine gtx970 erst duch ne navi10800xt ersezt ^^.
HerrRossi
Ja, so sieht es wohl aus...
k
kbcmz
1 Kommentare 0 Likes
Habe durch glückliche Umstände einen Ryzen 7 Pro 4570G bekommen, kein Gamer, läuft in allen Anwendungen super, bin absolut begeistert.
Follow Igor:
