Gaming GPUs Graphics Reviews
AMD Radeon RX 7800XT Review as Radeon Pro W7800 – The ideal gap filler between GeForce RTX 4070 and RTX 4070 Ti
I admit, it was tempting to test the current Radeon Pro W7800 as a gaming card, because AMD’s offerings between the already launched RX 7900 XT(X) and the RX 7600 are conspicuous by their noble absence on the market. At least the Radeon RX 7800XT has been ready for a long time, only that the chip is marketed as Radeon Pro W7800. Reason enough to simply test this object of curiosity as if it were a new gaming graphics card. That there were unexpected hurdles and problems, well. One should have actually known.
Important preface to the performance estimation
There are two things we need to clarify in advance. The first is how to interpret the power consumption. Since this is a workstation card, it is obviously designed for efficiency first and foremost. This means that it certainly operates closer to the sweet spot than the usual gaming behemoths. However, we can later extrapolate where the card would have ended up roughly via the efficiency comparison if AMD had turned on the tap significantly further here. We already have the values of the two NAVI31 cards, so this can be done very easily and plausibly. While the Radeon Pro W7800 has a TBP of 260 watts, my own extrapolation results in a TBP of around 270 watts for the RTX 7800XT based on the efficiency values of the other two NAVI31 cards. However, both values are not reached in gaming on average.
Since RDNA3 no longer allows us to emulate the cards directly, we unfortunately have to use the conversion method. I halve the memory with memtestcl . The program is able to allocate a predefined memory block and thus lock it completely for use by other programs. Thus, only 16 GB of VRAM is available. However, I can also confirm that it would not have made a difference and the advantage of 32 GB tends towards zero when gaming.
The second thing is almost a running gag, because what AMD delivers as a driver here is at least to be provided with a bigger question mark. Workstation or not, it works with NVIDIA, especially since I deliberately only use older games that don’t use any manufacturer-specific tricks. However, the fact that DXR is simply not applied in a game (although possible and enabled), but FSR works, is really weird, because then you even barely beat a GeForce RTX 4090 with DLSS. I still see the drivers as an endless construction site, so I really had to sort out and look very closely to remain plausible.
The AMD Radeon Pro W7800 and the hypothetical RX 7800XT
The Radeon PRO W7800 has been designed as a graphics card for professional users by AMD and was launched on April 13, 2023 It is manufactured in the 5-nanometer process and is based on the Navi 31 graphics processor in its specific design. This graphics card is compatible with DirectX 12 Ultimate, the latest generation of the DirectX interface. With a die area of 529 mm² and 57.7 billion transistors, the Navi 31 GPU is a large and powerful chip. Unlike the Radeon RX 7900 XTX, which uses the same GPU and has all 6144 shader units enabled, AMD has disabled some shader units on the Radeon PRO W7800 to achieve a specific shader count for this product.
As a result, the Radeon PRO W7800 only has 4480 shader units, 280 texture mapping units and 128 ROPs (Raster Operations Pipelines). Furthermore, 70 ray tracing acceleration cores are integrated. Up to this point, the data also exactly matches the colported RX 7800XT. After all, AMD has given the Pro card a full 32 GB of GDDR6 memory instead of 16 GB (clamshell), which are connected to the GPU via a 256 bit interface. The operating frequency of the GPUs is at a comparatively low 1855 MHz and can be clocked up to 2499 MHz if required, while the memory works at a speed of 2250 MHz (effective 18 Gbps).
As a pure dual-slot card in a blower design, it has dimensions of 280 mm x 110 mm x 40 mm. Furthermore, the AMD Radeon PRO W7800 draws its power from two rear 8-pin power connectors and has a maximum power consumption of 260 watts.
It offers various display ports, including 3x DisplayPort 2.1 and 1x Mini-DisplayPort 2.1, and connects to the rest of the system via a PCI-Express 4.0 x16 interface.
  RX 7900 XTX RX 7900 XT RX 7800XT
Compute units 96 84 70
AI accelerators 192 168 128
Ray tracing accelerators 96 84 70
Memory 24 GB GDDR6 20 GB GDDR6 16 GB GDDR6
Memory speed 20 Gbps 20 Gbps 20 Gbps
Memory bus size 384-bit 320-bit 245-bit
Game clock speed 2.3 GHz 2 GHz tbc
Output DisplayPort 2.1 DisplayPort 2.1 DisplayPort 2.1
TBP 355 W 315 W tbc
MSRP 1000 USD 900 USD tbc
With this, the first page is done and we are slowly preparing for the test event.
1,698 Kommentare 1,031 Likes
Interessanter Test und interessante Karte! Das Rummachen mit den Treibern hört sich allerdings gar nicht so spaßig an. Und der von Dir vermutete Grund, warum es die 7800XT so nicht gibt, hört sich leider als sehr wahrscheinlich zutreffend an: die Überbestände der Radeon RX 6800(XT) und RX 6900XT. Die will AMD wohl egal wie abverkaufen, und da käme die deutlich bessere 7800XT doch sehr ungelegen. Schade eigentlich! Sowas ist auch bei den APUs mein Verdacht, nämlich, warum die Phoenix APUs (v.a. die U Serie) seit Monaten nur angekündigt aber nicht lieferbar sind; da gibt's wohl auch genug 6000er APUs auf Halde, die erst Mal verkloppt werden müssen/sollen. Wenn das mal nicht in die Hosen geht, AMD verspielt hier eine große Chance, sich sehr von Intel abzusetzen! Und Meteor Lake scheint im Zeitplan zu liegen, d.h. Q3 ist es soweit.
Zum aktuellen Testmodel (der Pro W7800): Neben dem von mir sehr bevorzugten Blower Design (ich bin da halt altmodisch) auch sonst eine schmucke Karte, und mit 32 GB RAM in Clamshell gut versorgt. Auf Benchmarks mit Anwendungen bin ich schon gespannt! Was kostet das gute Stück denn?
Genie_???
219 Kommentare 69 Likes
Das AMD es nicht mal dauerhaft hin bekommt den Idle Stromverbrauch niedrig zu halten, finde ich schon ein Trauerspiel.
Es ist also stets Glückssache und hängt wohl auch von den verwendeten Monitoren ab, ob die Karte mit 2 oder 3 Monitoren im Idl hoch schaltet oder nicht.
Das es grundsätzlich Sparsam geht, sehe ich am nunmehr verwendeten Treiber wo meine W6600 auch mit 3 Monitoren im ruhigen Desktop-Betrieb ~5W zieht.
Zuvor schaltete sie stets den Speicher & GPU fix hoch und zog, vollkommen unnötige ~20W.
Schon seit 2020 war kein Treiber (schon bei der alten Karte) in der Lage einen 2. Monitor ohne mörderischen Stromverbrauch zu betreiben. Bei manchen Treibern gab es das Problem sogar mit nur einem Monitor.
echolot
1,118 Kommentare 875 Likes
Ich hätte die 7800XT ehrlich gesagt besser als eine RTX 3090 eingeschätzt und wünsche mir endlich FSR 3 als Antwort auf Nvidias DLSS FG. Vielleicht gibt es ja einen guten Sommer für AMD...und für uns.
Derfnam
7,517 Kommentare 2,032 Likes
Hat das traditionell tadellos träge Tippitoppitreiberteam aus Toronto mal wieder ganze halbe Arbeit geleistet?
P
Pokerclock
486 Kommentare 421 Likes
Meine Erfahrung mit AMD-Workstation-Karten hält sich arg in Grenzen. Hauptsächlich weil meine Kunden keine AMD-Grafikkarten haben wollen. Egal ob Gaming oder Workstation. Jede AMD-Karte, die ich bislang angeschafft habe, war für mich ein Minus-Geschäft. Es ist davon abgesehen tatsächlich schon Jahre (!) her, dass mal wer eine AMD-Workstation-Karte angefragt hat. Da ging es um das Radeon Pro SSG Special-Teil mit angelöteten 2 TB Flash-Speicher...
AMD muss hier dringend was machen und die Zusammenarbeit mit den jeweiligen Software-Entwicklern intensivieren sowie an den Treibern arbeiten.
Die werben ja gerade aktiv mit Solidworks, allein mir fehlt der Glaube. Ich werds testen.
R
RX_Vega1975
165 Kommentare 46 Likes
und endlich mal etwas Neues zu FSR 3.0
da weist nix dazu,-
sollte ja schon vor Monaten kommen.
Bis Ende dieses Monats sollte wohl der Release/ Zumindest dessen Release Ankündigung erfolgen.
P
Penman
28 Kommentare 28 Likes
Die Frage stelle ich mir seit Monaten. Ich habe mir selbst ein Budget über 450 Euro für die 6800 (XT) gesetzt. Dass die Karte sich immer noch an den UVP klammert, obwohl der Nachfolger längst auf dem Markt sein müsste, ist wirklich verwunderlich. Wenn sie die Lager leer haben wollen, sollten die Preise vielleicht mal etwas fallen.
Dass das Workstation Pendant längst auf dem Markt ist, habe ich nicht wahrgenommen und Tests dazu halten sich auch eher in Grenzen. Aber die Rechenleistung trifft in etwa meine Erwartungen. Dass die Effizienz höher ist, ist erfreulich. Bedauerlich, dass die Karten im Multi Monitor Betrieb immer noch unverhältnismäßig mehr Strom aus der Dose ziehen.
Was taugt so ein Radiallüfter heute eigentlich? Meine letzte Karte mit einem war die HD 3870. Der Klang war ganz ok, aber wenn sie gearbeitet hat, wurde der schon hörbar. Mit nur 2 Slots und einem Schaufelrad muss da doch sicher eine entsprechende Menge Luft durch die Finnen gedrückt werden. :D
Btw. Hübscher Fingerabdruck an der Slotblende. Erinnert mich an einen Vortrag vom Chaos Communication Congress in dem über Fingerabdrücke von fotografierten Personen referiert wurde.
D
Deridex
2,224 Kommentare 858 Likes
Zumindest mit etwas älteren Workstationgrafikkarten von AMD läuft Solidworks anscheinend ohne größere Probleme.
c
cennax
26 Kommentare 18 Likes
Netter test!
Ich sehe das ähnlich, dass es sich eventuell eher weniger lohnt eine stark beschnittene 70 CU Karte zu veröffentlichen. Der Unterschied zu den 60(?) CU von Navi 32 wäre ja auch eher gering, falls endlich mal eine Karte kommt.
RedF
4,888 Kommentare 2,717 Likes
Kein Teardown erlaubt gewesen?
Schade : )
w
wertzius
54 Kommentare 43 Likes
Scheinz wirklich nicht übel zu sein - bei einer 2-Slot Variante könnte ich glatt schwach werden meine RX6800 zu ersetzen. Nicht weil es unbedingt sinnvoll ist, sondern weil es Spaß macht und das + bei Raytracing und gute 25-30% mehr Leistung würde ich gern mitnehmen.
@Pokerclock Also die Abneigung der Gaming-Kunden gegen AMD kann ich nicht verstehen - die der professionellen Kunden schon eher. Aber das ist AMDs Imageproblem, von den Features her ist der AMD Treiber den Nvidia überlegen. Aber da gibt es ja reichlich Videos auf Youtube zu. 2 aktuellere:
Sprachliche Feinheit: Bei der Formulierung "Sie bietet diverse Display-Anschlüsse, darunter 3x DisplayPort 2.1 und 1x Mini-DisplayPort 2." würde ich erwarten, dass die Karte mehr als 4 Display Anschlüsse hat. Sonst fände ich ein "Sie bietet diverse Display-Anschlüsse: 3x DisplayPort 2.1 und 1x Mini-DisplayPort 2." passender. Geht das nur mir so?
DMHas
59 Kommentare 18 Likes
Interessante Karte! Mal sehen wo sich der Preis einpegeln wird. Ehrlich gesagt, hoffe ich, das AMD's Rechnung aufgeht und NVidia in Bedrängnis bringt (wenn der Preis stimmt).
Andererseits bestätigt mich der Test, dass der Kauf der 7900XT Vapor-X richtig war. (Leider ist jetzt die CPU die Bremse.)
P
Pokerclock
Was nutzen Features, wenn der Treiber selbst häufig instabil ist und/oder nicht auf aktuelle Spiele optimiert. Kommt oft genug vor, dass AMD erst Wochen bis Monate nach Veröffentlichung von AAA-Games harte Probleme korrigiert bzw. die Entwickler, weil diese sich erst einmal auf Nvidia konzentrieren. AMD muss hier bei sich selbst aber auch mit den Software-Entwicklern dran arbeiten. Man hat oftmals das Gefühl, dass die Treiberentwicklung ein Nebeneinander statt Miteinander ist.
Ich habe mit AMD auch schon genug random Sh.it erlebt, den Du bei Nvidia in dieser Häufigkeit und dem Ausmaß eben nicht hast. Es hapert schlicht an Konstanz und Verlässlichkeit bei AMD. Und daher rührt dann auch die Abneigung vieler (Privat-)Kunden. Dementsprechend habe ich auch keinen Bock als Händler bzw. Vermieter hier ein Produkt zu empfehlen, das dem Kunden und damit auch mir im Nachgang mehr Arbeit macht als Nutzen/Marge bringt.
echolot
Die Preise werden erst aufbrechen wenn der Wettbewerb härter wird. Wir hoffen auf Intel...
RX480
1,887 Kommentare 879 Likes
Wie groß ist denn der Marktanteil in UWQHD, lohnt sich so ein Salvage-Salvage Modell seitens AMD extra für Gamer?
(die Amis werden wohl eher am 4k-TV ne 7900er nehmen)
btw.
In WQHD wird wohl eher Navi32 bei P/L passen, .... nach m.E. ist RDNA3 in der Auslastung net sooo durchgängig ideal wie RDNA2.
(Dadurch sind die Ergebnisse seeehr gameabhängig , ... ähnlich wie bei Ampere ne 3080Ti, z.Bsp. in C3 ... siehe Anhang, läuft erst >WQHD so richtig )
O
Oberst
345 Kommentare 134 Likes
Bei den APUs werden doch die Rembrandt auch als 7000er verkauft, daran kann es nicht liegen. Also die 7x35U Modelle sind Rembrandt, quasi eine Neuauflage der 6xxxU Modelle.
Meiner Erfahrung nach stellt AMD immer grob Übergang Q1 auf Q2 die neuen Geräte vor und auf dem Markt sind sie dann Ende Q2. Mein Dell G5 habe ich auch erst ab Juli bestellen können, die U Modelle kamen damals sogar noch später.
w
wertzius
@Pokerclock Das meine ich mit schlechtem Ruf - welches AAA Spiel der letzten 2 Jahre hatte denn keine Day One Treiber seitens AMD am Start?
Keine? Meiner Meinung nach eher ein Gefühl, als eine Sachlage, die du da beschreibst.
Antwort 4 Likes
Follow Igor:
