Artificial Intelligence GPUs Latest news
AMD Radeon 7900 XTX achieves 890% speed increase in generative AI with Stable Diffusion Optimization
NVIDIA rightfully dominates the scene in the AI discussion. their GPUs are ready to go and enjoy precedence among professionals and companies looking to enter the world of AI. However, just this week, both Intel and AMD tweaked their software stacks to deliver significant speed increases in the generative AI space. These updates resulted in AMD’s RTX 7900 XTX offering a better performance ratio per dollar invested than an NVIDIA RTX 4080 in the context of generative AI, especially when using Stable Diffusion with A111/Xformers.
Source: AMD
Note: Tuning for GenAI, much like tuning for crypto mining performance, will have mileage vary significantly depending on the model/configuration being used. This article is about the most common A111 Xformers config (you can get a running tally of average performance by GPU here: https://vladmandic.github.io/sd-extension-system-info/pages/benchmark.html) but there *are* hyper tuned boutique optimizations where the NVIDIA RTX 4080 is faster still.
Using Microsoft Olive and DirectML instead of the PyTorch path could increase the speed of the AMD 7900 XTX from 1.87 iterations per second to 18.59 iterations per second. AMD’s detailed instructions for this can be viewed. The level of performance achieved in Automatic111 could have similarities to Stable Diffusion’s SHARK-based approach and will undoubtedly solidify the company’s presence in the generative AI space. It should also be apparent with this that the 7900 XTX also has potentially better GenAI performance per dollar in Stable Diffusion /A111 compared to the similar RTX 4080, at least under current pricing.
The lowest priced NVIDIA RTX 4080 available at Newegg at the current time (as of 8/19/2023) is the MSI Ventus GeForce RTX 4080 16GB. The least expensive AMD Radeon 7900 XTX, which is also available at Newegg, is the MSI Gaming Radeon RX 7900 XTX 24GB. Before analyzing the numbers, however, it should be noted that the AMD approach might require a bit more technical understanding than the NVIDIA approach. The AMD approach uses Microsoft Olive instead of PyTorch, and most automated installers might not install the necessary dependencies on their own. So, when considering the convenience factor, NVIDIA might remain the more straightforward choice. Still, professionals and small businesses could usually overcome the initial installation challenges, especially if the cost base is attractive enough – which could be the case here.
As can be seen, AMD silicon is finally starting to shine in the GenAI space. As a result, it is now possible to achieve a higher value than the RTX 4080 in Stable Diffusion A111. The AMD 7900 XTX is said to achieve a speed of 18.59 iterations per second at a cost of $52.1 per iteration, while the NVIDIA RTX 4080 achieves a speed of 19.41 iterations per second at a cost of $56.6 per iteration. With the less common SHARK implementation, the Radeon 7900 XTX’s price-to-performance ratio could even be as low as $46.6 per iteration. AMD is potentially a serious contender for consumers who have an interest in generative AI.
This could also mean that AMD could grow into a significant competitor to NVIDIA’s AI ambitions if given proper attention. While the majority of people don’t have LLMs in their basements, GenAI as well as SLMs/ULMs could become more ubiquitous and an important part of numerous productivity workflows in the next 12 months. How Intel and AMD position themselves in a market where NVIDIA holds a significant lead could determine how they fare in an AI-dominated world.
Source: AMD
Guest
Und das gesparte Geld verballert man dann bei der Leistungsaufnahme?
Nulight
250 Kommentare 170 Likes
Schön zu sehen.
Bisweilen arbeite ich mit der 4090 in Stable Diffusion, welche auch mehrere Optimierungen erhalten hatte.
Macht doch Spaß Stable Diffusion.
Laboratory, pc battlestation, led light, watercooling, hardware, old men in center, old men, wearing glasses, looking at viewer, gaming room,
Titel: Die ersten Quantenchips werden auf Herz und Nieren getestet.
Schönen Sonntag
Y
Yumiko
546 Kommentare 248 Likes
Die max. Leistungsaufnahme sind gar nicht so unterschiedlich - die laufen dabei ja auf Vollast. Wenn man bei der Dauergeneration von KI ist, könnte es interessant werden, ansonsten alle Stunde mal eine KI-Funktion in der Bildbearbeitungssoftware anklicken sollte nicht so stark ins Gewicht fallen.
Soweit sind wir aber noch nicht überall - könnte für die nächste Generation der Software/Hardware eher entscheidend sein und da wissen wir noch nichts über die Hardware und deren Leistung in dem Segment.
8j0ern
2,756 Kommentare 854 Likes
Dann schauen wir mal, wer den Rechen-Job schneller erledigt hat.
Race to IDLE matters, wer schneller fertig ist, braucht auch schneller kein Strom mehr. ;)
1,698 Kommentare 1,031 Likes
Wobei es bei Nvidia eben immer auch noch einfacher ist (weniger Gefrickel). Darf man glaub ich nicht unterschätzen wie wichtig das ist; vielleicht bin ich mit den Jahren auch etwas fauler geworden, oder weiser. Warum mit dem Kopf durch die Wand, wenn's daneben auch ne Tür gibt?
Nulight
Nvidia macht meiner Erfahrung nach, circa 15 Jahre im PC Bereich, die wenigsten Software und Hardware Probleme.
Das ist aber ganz alleine meine Erfahrung und ich hatte beides.
Jedes Mal, wenn ich eine AMD Karte hatte, sie funktionierte, aber es war eben nur okay aber nicht wirklich so rund und stressfrei.
Da ich öfter Probleme mit dem Treiber hatte, wurde es nach der 7900XT die 4090, einbauen, Treiber drauf und läuft.
8j0ern
Samir Bashir
