GPUs Graphics Reviews
AMD launches the Radeon RX 6600 without XT for the midrange – XFX RX 6600 SWFT 210 SPEEDSTER 8GB Review with small hurdles
With the Radeon RX 6600 released today, AMD rounds out the Navi portfolio even further down the line. Since there are once again no reference cards (AMD is following NVIDIA’s lead here with the GeForce RTX 3060), today’s launch article will thus once again use a board partner card. It will be exciting to see if the XFX RX 6600 SWFT 210 SPEEDSTER 8GB tested today matches what I had already tested as an emulated card some time ago.
Of course I don’t want to spoil too much in advance, but I can give myself a pat on the back in advance. You will see in a moment how much this was already “On Point” at that time. But first I dedicate myself to the chip as such and then also to the test sample, which this time comes from XFX and was adapted quite cost-reduced for the market to be able to meet the MSRP.
But before we really start, we have to write about the availability, because this will also influence the price. Since all this can’t be predicted, I have to consult the MSRP of 339 Euro, even though you’ll hardly see anything in this price range in the shop window. At least, certainly not for everyone who would like to buy such a card. AMD’s price is based on the GeForce RTX 3060, which is certainly about right in terms of performance. Only the rest is done by the dear retailer with a gesture of generosity.
And for those who don’t know what I mean by emulated card, here’s the link again to remind you and compare later: AMD Radeon RX 6600 Non-XT Benchmarks – Equal to GeForce RTX 3060?
Preliminary remark on the test sample
The title also says something about small hurdles, and I’ll have to write about that in a bit more detail when we get to the teardown. A lot of things already went wrong out-of-the-box and I had to play MacGyver once again with hot glue and some inspiration. The left fan above the GPU (the most important one, because the tacho signal is also tapped here) already said goodbye to the eternal hunting grounds with an audible crackling and the dreaded smell of dead electronics when it was switched on for the first time. I couldn’t find a replacement in a hurry, so I had to modify the card a bit.
By the way, I am very satisfied with the result of my transplantation and also the construction diary in the context of the teardown will provide the necessary transparency, so that everything is correct. In the meantime another card came from Powercolor and I can surely publish a counter test this week. Until then, you’ll have to live with my “Frankenstein mod”, but gaming performance certainly won’t be lacking. Problems are meant to be solved.
The Radeon RX 6600 with Navi 23
The AMD Radeon RX 6600 Non-XT relies on the Navi 23 XL GPU, which only has 28 instead of 32 compute units or 1792 instead of 2048 stream processors. Thus, the card is already at a disadvantage of about 12 percentage points on paper, if the clock is set at the same level. The card also features, like the XT, 32MB of Infinity Cache and 8GB of GDDR6 memory running over a 128-bit wide bus interface. The Navi 23 XL GPU itself measures 237 mm² and consists of 11.06 billion transistors.
In contrast to the GT, the memory speed only uses 14 Gbps modules from Hynix with 1750 MHz (instead of the usual 2000 MHz). But the memory allows overclocking up to 1900 MHz without any problems. However, the GPU is still not the smallest chip in the RDNA 2 family, as Navi 24 is still expected here for the absolute entry-level range.
The XFX card is a real lightweight with just under 640 grams, the front is dominated by two current 9.5 cm fans, whose design we already know from the other XFX cards. The rest is ABS in black with no color accents and no illuminated logo on the top. Saving is the order of the day and so everything remains dark for the time being. So it’s not a visual thrill, but it’s not a complete derailment either. It’ll be fine, if the price is right.
The card is a pure dual-slot design and requires an additional 0.4 cm for the rear planking with a backplate. The cooling fins are vertical and on the top we see a single 8-pin power supply connector. The rest, however, is completely unspectacular.
The backside of the board is covered by a backplate, as already written. The air opening also reveals that the board with its 18 cm length is quite a bit shorter than the 24.5 cm long card (slot bracket to card end). The height, however, is more generous at 12.5 cm.
The slot bracket is closed, carries 1x HDMI 2.1 and three current DP connectors. The USB Type C is omitted. The whole thing is powered via an 8-pin socket. More about this on the next page in the teardown.
The screenshot from GPU-Z then provides information about the remaining data of the card:
Again, I have a table for all statisticians among you, before it really gets going from the next page on.
Model RX 6600 (XFX)
RX 6600 XT (MSI)
RX 6700 XT (Reference)
RX 6800 (Reference)
RX 6800 XT (Reference)
RX 6900 XT (Reference)
GPU Navi 23 Navi 23 Navi 22 Navi 21 Navi 21 Navi 21
Process node 7 nm 7 nm 7 nm 7 nm 7 nm 7 nm
The Size 237 mm2 237 mm2 336 mm2 520 mm2 520 mm2 520 mm2
Transistors
11.06 billion 11.06 billion 17.2 billion 26.8 billion 26.8 billion 26.8 billion
Compute units 28 32 40 60 72 80
Shader 1792 2048 2560 3840 4608 5120
TMUs/ROPs 112/28 128/32 160/64 240 / 96 288 / 128 320 / 128
Game clock 2044 MHz 2428 MHz 2424 MHz 1815 MHz 2015 MHz 2015 MHz
Boost Clock 2491 MHz 2607 MHz 2581 MHz 2105 MHz 2250 MHz 2250 MHz
Memory GDDR6
8 GB 8 GB 12 GB 16 GB 16 GB 16 GB
Infinity cache 32 MB 32 MB 96 MB 128 MB 128 MB 128 MB
Memory bus 128-bit 128-bit 192-bit 256-bit 256-bit 256-bit
Memory clock 14 Gbps 16 Gbps 16 Gbps 16 Gbps 16 Gbps 16 Gbps
Bandwidth 224 GB/s 256 GB/s 384 GB/s 512 GB/s 512 GB/s 512 GB/s
TDP 140 W 160 W 230 W 250 W 300 W 300 W
LEIV
1,558 Kommentare 645 Likes
Schöne kleine GPU, wäre schön wenn es davon auch ne Passiv Variante gäbe
Oder eine Asus x Noctua Combi mit einem A12 oder so
Preise sind hier sogar zum Start eine Katastrophe, auf Mindfactory 500 Euro für die RX 6600
Guest
Zu teuer. Die 3060 hat 12GIB VRAM und ist von der UVP preiswerter. Die Effizienz spricht für sich, lässt sich AMD anscheinend aber mittlerweile auch vergolden. Schade. Mir kommt das langsam so vor, als wollen die gar keine Konkurrenz, die Preise sind doch gut für die, wird einem alles aus der Hand gerissen.
Siehe Öpec beim Oel, fördern nicht, dann wirds knapp und zapp - teuer, auch ohne Ökoaufschläge. Scheint der neuste Trend in der Industrie zu sein, um ein must have aufzubauen.
M
Morgrain
190 Kommentare 140 Likes
Laut den Reviews in etwa auf dem Niveau einer 2060 (super). Sogar leicht darunter. Und das für UVP Preise (customhersteller) von jenseits der 400 Öcken.
Zur Erinnerung: Die 2060 (super) ist eine Karte, die vor mehr als 2 Jahren released wurde...
Das... ist ein schlechter Scherz.
Für 200 € wäre das hier der Burner schlechthin, für die aufgerufenen Preise allerdings... kann ich nur schulterzuckend nach dem Sinn dahinter fragen.
Am besten fange ich erst garnicht mit dem Thema 5600 XT an, die mit einer ursprünglichen UVP von 299 € im Vergleich zu dem "heutigen" Produkt natürlich... positiv rüberkommt...
10,484 Kommentare 19,638 Likes
Es ist keine WQHD-Karte :D
M
Morgrain
Etwas fragwürdig bei UVP Preisen von jenseits der 400 € (hab zumindest bei Asus und Gigabyte reingeschaut in die Shops) und bei aktuellen Straßenpreisen (Verkaufsbeginn, Zentraleuropa) von mehr als 600 €.
Aber ja, klar, die Preise sind aktuell alle bescheuert. Ändert aber nichts daran, dass AMD sich hier nicht in Full HD reinsetzen kann, wenn man mehr Geld verlangt für Leistung, die man vor Jahren schon für weniger Geld angeboten hat - im gleichen Segment.
Aber Ende verliert nur der Kunde. Also wir. Das macht mich immer etwas traurig...
Hätte mir mehr erwünscht, aber bei den aktuellen Preisen auch in den Fabriken bei Samsung/TSMC kann man wohl nicht mehr erwarten.
M
Morgrain
Im Zweifel einfach solche Shops für die Zukunft umgehen. Ich persönlich habe mir ein Limit von 20% über UVP gesetzt und Shops, die mehr wollen, unterstütze ich nicht mehr. Von Scalpernate & Co. müssen wir natürlich erst garnicht anfangen.
Gibt da auf Reddit übrigens auch nette Listen. Auch und vor allem zu Shops beispielsweise, die ihre Altbesteller stornieren und/oder Neubesteller zu höheren Preisen bevorzugt beliefern, obwohl noch Reservierungen/Bestellungen (u.a. bereits bezahlt!) offen sind.
Kurioserweise ist Amazon bei Release von solcher Hardware eine gute Adresse. Habe dort meinen 5950x für knapp 950 € zu Release bekommen.
LEIV
Meine 6600 XT hab ich von Mindfactory für 410 Euro zu release gekauft, keine Ahnung warum die jetzt so viel aufschlagen direkt.
Guest
Also UVP 40€ weniger als die XT, dabei aber deutlich weniger wertige Elektronik verbaut und im Schnitt 16% langsamer, manchmal auch 20%. AMD hätte den UVP hier niedriger ansetzen müssen. Auch wenn die UVPs eh utopisch sind...
Zumal die XT + OC auch wesentlich mehr WQHD geeignet ist, als die non XT. Das ist bei dem Mangel momentan auch ein Faktor.
Guest
Winter Gaming Zeit steht vor der Tür + die letzte Aufrüstung ist immer länger hier + Mining Kurse gehen immer noch weiter hoch.
Es wird noch schlimmer werden...
Alkbert
959 Kommentare 747 Likes
Auch ein gutes dreiviertel Jahr, nachdem ich meine Asus 2080 Dual OC im Zweitrechner bereits ausgemustert, ersetzt und upgegradet haben wollte bin ich immer noch keinen Schritt weiter - und das wird wohl so schnell auch nix. Der Punkt ist unter dem Strich, dass mir das Gehirn noch nicht völlig ausgetrocknet ist und ich definitiv keine Graphikkarte kaufen werde, die mehr kostet, als die Standheizung in meinem Auto - und dort sehe ich erheblich mehr Gegenwert.
Genie_???
219 Kommentare 69 Likes
Und? Soll sich AMD jetzt hinstellen und nur für den schönen Schein eine UVP von 250 dran schreiben, den darbenden^^ Handel subventionieren und spätestens 15 Minuten nach Verkaufsstart liegen die Preise ohnehin bei >500€.
Solange die Marktpreise irgendwo hinter dem Mond sind, ist das für den Hersteller die einzige Möglichkeit an den Marktpreisen zu partizipieren.
Wenn die irgendwann (nächstes Jahr?) wieder auf diesem Planeten sind, kann man die Preise locker nach unten anpassen. Was meinst, was los wäre, wenn AMD nachträglich die UVP von 250 auf 350 hochschrauben würde.
Edit: die einzige noch bei gh gelistete Karte geht aktuell für 620 über den Tisch.
Alles Klar?
Was dein 1440p Review angeht, da verlasse ich mich doch lieber auf die Zusammenfassung im 3D-Center.
Wer 1440p spielen will, sollte sich aktuell eh besser eine 3060ti, 6700xt oder besser anschauen.
Und was letztes oder vorletztes Jahr war, kannst heutzutage eh vergessen.
Guest
Gut ich hab für meine alte RX 570 8GB auch 3x so viel bekommen wie in normalen Zeiten.
Auf 6600XT aufgerüstet sind das +110-120%
Für mich hat es sich gelohnt. Gerade weil ich für die 570er später dann fast nix mehr bekomme. Und ne Karte brauch ich halt im System.
@Genie_???
Die non XT wäre mir in Hinblick auf WQHD auch etwas zu schwach. Das geht mit der XT + OC eigentlich noch sehr gut auf Ultra.
Zukunftssicher in WQHD ist aber natürlich die 6700XT. Aber naja, sie wird ja von AMD auch mit Zukunftssicherheit für WQHD beworben. Aktuell geht die 6600XT in WQHD mehr als klar! Hab bei noch so fordernden Spielen 60-90FPS. Alles Ultra ohne Ray Tracing.
Guest
Das Problem ist, das sie sich mit der (RX) 5700 umherschlägt und wenn es über FHD geht verliert, gleiche Leistung für mehr Geld, was soll das? Die 6600 ist eine extreme Mogelpackung, RT sieht sie keinen Stich gegen die 3060 und ist auch so langsamer. Kein DLSS und FSR hilft in 1080p kaum. 279 mehr kann dafür nicht verlangen, weil die 3060 12GIB VRAM hat. Wie gesagt, AMD lässt sich mittlerweile die Effizienz vergolden.
Derzeit ist es egal, weil die Marktpreise jenseits von gut und böse sind, aber positiv ist das auf keinen Fall. Tut mir Leid AMD, aber immer wieder an der Preisschraube drehen ist nicht i.O.. Das Saubermannimage preiswert und leistungsfähig zu sein, zerbröselt mittlerweile auch CPU Sektor.
Die 6600 sollte klar die (RX) 5000 Serie erreichen und das tut sie nicht. Dann gibt es auch keinen Grund AMD zu kaufen.
s
stift_AT
35 Kommentare 3 Likes
Hallo,
danke für den interessanten Test. Mal schauen, zu welchem Preis die zu haben ist. In meinem alles andere als High-End Rechner ist eine R9 280 drinnen (ist ja zufälligerweise auch heute wieder in einem Bericht getestet worden). Leistungsmäßig auch ausreichend; habe aber Angst, dass sie mal das zeitliche segnet.
Von der Leistungsaufnahme müsste die 6600er klar weniger als die R9 280 brauchen (Netzteil ist knapp bemessen)?
UVP ist mir schnuppe; mir geht es rein um den Preis im Laden. Welche Alternativen hätte ich denn, wenn ich unter 500€ bleiben möchte?
Guest
Ich hab in WQHD mehr als das Doppelte an FPS als bei der Polaris RX 570 8GB vorher?! Alles Ultra ohne Ray Tracing...
Die Karte ist in WQHD 110-120% schneller! Weiß wovon ich rede, da ich beide Karten habe/hatte. Im Schnitt 60-90 FPS bei neusten Titeln.
Und die 6600XT ist doppelt so schnell wie eine RX 580 8GB.
Aber ist halt auch die XT. Die 6600 ist im Schnitt 16% langsamer als die 6600 XT.... Trotzdem noch deutlich schneller als eine RX 570/580!
Polaris für 200€-250€ Zeiten von 2016/17 sind vorbei. Schon vor 2020 sind die Preise deutlich gestiegen! Der UVP von AMD für die 6700XT ist mit 480€ auch viel zu hoch. Früher hätte eine Karte in der Leistungsklasse 100€ weniger gekostet.
@stift_AT
Für deine alte R9 280 wirst leider nicht mehr viel Geld bekommen. 3GB gibt es nicht viel für. Das ist bei meiner Polaris 8GB ganz anders gewesen.
Alles ab 6GB VRAM verkauft sich gebraucht Bombe!
Guest
Hab es mal korrigiert, eine 0 vergessen. RX5700. Ist nun mal so das man die Vorgänger irgendwie erreichen und vorbei muss. Eine X070 von Nvidia war zuweilen dicht an dem Topdog der Vorgängergen dran. 1070 versus 980ti usw.. 3070/3070ti versus 2080s/2080ti.
Da RX5000 die Mittelklasse war muss man dort auch auch vorbei. Schafft man aber nicht. Die Karte ist RT nicht mal so schnell wie eine 2060, wäre mir zu wenig. Auf einem 1080p Display kann man das ruhig mal einschalten.
Unter FHD ist sie ein paar Frames schneller als eine 5600xt (ca.10-20%), wo bleibt da der Fortschritt? Das ist doch kein Upgrade. Hier scheint klar das Speicherinterface zu behindern (wie unter UHD) und warum sie fast 30% hinter einer 6600xt zurückfällt müsste AMD mal erklären. Eine 3060FE ist haushoch überlegen und kostet UVP weniger. Nichts weiter als mal wieder an der Preisschraube zu drehen.
M
Moeppel
883 Kommentare 314 Likes
Das Ergebnis, eines maximal dysfunktionalen Marktes.
Ob Intel der Heilsbringer werden wird? Es bleibt "spannend". 🤡
Inxession
56 Kommentare 45 Likes
Weil einfach kein Bestand da ist ... die wenigen Karten verkaufen sich auch zu diesem Preis. PUNKT
LEIV
Naja, sind immer noch Karten da, und jetzt kann man sogar 3 statt 1 auf einmal bestellen
Follow Igor:
