Cooling Fans Reviews
Alphacool Rise Aurora 120 mm ARGB fan – A surprise with extremely high throughput and acoustic restraint
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
With street prices starting at around 16 Euros, Alphacool positions the brand new Rise Aurora 120 mm as a mid-range fan for cases and especially radiators. Without wanting to spoil it in advance: the fan was a real and above all positive surprise, because it was not only worlds better than the direct predecessor model in the test, but it could also more than hold its own against the reference fan in many respects. Of course, that’s a lot of advance praise, but it’s well justified by the test results.
Alphacool has not been lumpen and uses one of the renowned manufacturers for the fan instead of a rather cheap low-budget scoop. With Power Logic, an experienced manufacturer has been chosen who also supplies other suppliers with suitable products. In the end, of course, as always, you get what you pay for and not an ounce more. Which brings us to the weight, which turns out quite decent at 180 grams, but also relies on a decent drive. We’ll have something on that in a minute.
Yes, the part shines colorful and ARGB seems to be the first civic duty at the moment anyway – so here at Alphacool they have served the market appropriately. What’s appealing about this is the fact that both the translucent hub glows, as well as a thin outer ring. Despite all this bulb implementation, the diameter of the rotor blades doesn’t really suffer, so the fan not only lights up, but also delivers properly.
The fans can be cascaded on the ARGB, but Alphacool does not include an adapter to the motherboard’s Preci-Dip connector (5 volts). Of course, other Alphacool products such as Eisball, Eisbär, Eiswolf & Co already come with adapters and you can simply clamp the fans with it, but who wants to use this fan outside the Alphacool universe, must put an extra adapter in the Alphacool shop on top. With 5 euros one is already well there, but for it the purchase price of the fans is rather fair.
In order to achieve this, Alphacool relies on somewhat cheaper plain bearings, but due to the design, this only has a negative effect on the service life if the fan is directly exposed to heat. The maximum 40 °C on a radiator is certainly not one of them, even when used as a case fan there is rather no alarm to fear. It is better to use a good plain bearing than a clumsy double ball bearing or a very cheap FDB bearing, whereby plain bearings are characterised by a more restrained noise level, especially at lower speeds. So you can’t have everything.
Form factor 120 mm
Starch 25 mm
PWM Yes
RGB Yes
Decoupled Yes
Color Frame Black
Accent color none
Color rotor Translucent
Weight in g 180
min. speed 0 (semi-passive)
max. speed 2500 (2750)
Volume flow m3/h 118.9
Flow rate CFM 69.98
static pressure mmH2O 3.17
Sound pressure dBA 31.5
Life Time hrs 50,000
On the next page you will first see how and what we test and why. Understanding the details is extremely important in order to be able to objectively classify the results later. The differences between many models are more in the details and THE best fan for all situations can hardly exist. There is a certain optimum in every situation and of course there are also good all-rounders. But they usually come at a price. But if you plan to use 60mm radiators for example, you might save money by choosing the best model for your application, which might not perform so well as a case fan. And vise versa, of course.
For the new ones I also have the original data sheet as PDF at hand:
DE_1020781_Alphacool_Rise_120mm_Luefter_Datenblatt
Since the fan is not yet listed in Geizhals, I have exceptionally times the shop link included:
Aurora Rise 120 mm RGB in the Alphacool Shop
Tim Kutzner
857 Kommentare 700 Likes
16 Euro sind Mittelklasse-Preise bei Lüftern?
Aber auch nur, wenn man sonst nur eLoop oder Noctua kauft :D
Aber zumindest taugt er was und sieht auch noch ganz schick aus
Der Corsair kostet doppelt so viel. Mittelklasse sehe ich zwischen 10 und 20 Euro.
ARGB unter 15 Euro mit solchen Daten? Such mal :D
Tim Kutzner
J
Javeran
16 Kommentare 4 Likes
Danke für den Test. Hätte ehrlich gesagt nicht gedacht dass der Lüfter so gut performt, doppelten Dank für die Erleuchtung.
@Igor Wallossek besteht die Chance auf einen Test des "Wunderlüfters" von Asus den XF120?
Wenn die uns einen schicken, gern. MSI habe ich schon angebohrt :)
Opa-Chris
87 Kommentare 122 Likes
Gefunden!
Wobei der Arctic bei 500rpm und 1000rpm bei leicht mehr (Gehäuselüfter) oder gleich bis leicht weniger (Radiator) Durchsatz deutlich leiser ist. Und günstiger ist er auch noch.....und mehr Garantie....und ich bin einfach zufrieden mit dem. :LOL:
Der Wechsel vom Alphacool Eiszyklon Aurora LUX PRO 2 Digital RGB zum Arctic P12 PWM PST A-RGB war wirklich ein krasser Sprung, was Durchsatz und Lautstärke betrifft. Kann ich wirklich nur weiterempfehlen....
g
gerTHW84
413 Kommentare 253 Likes
Sind die Lüfter von BlackNoise noch ein Thema? Die haben doch mal vor ein paar Jahren Wellen geschlagen, weil sie vermeintlich das Lüfterrad neu erfunden haben wollen?
Martin Gut
7,955 Kommentare 3,710 Likes
Einen 12er und einen 14er hat Pascal bereits getestet:
Mich würden aber auch noch die langsameren Modelle interessieren, weil man damit wirklich lautlose PCs bauen kann. In meinem werkeln 3 B14-1.
Pascal TM-Custom
1,122 Kommentare 1,361 Likes
Ich hab noch welche von NB da das dürften genau die sein die du meinst.
Ich schau mal welche ich habe und ich teste ja alles was ich in meinem Großen Schrank der Lüfter so habe.
Da liegen noch Lüfter im 3 Stelligen Bereich die ich alle testen muss. Dann gibt's auch eine ordentliche Datenbank für euch wir sind schon dran das das in Zukunft für euch bereitsteht.
RX480
1,887 Kommentare 879 Likes
Derselbe Humbug wie beim letzten Test!
Für highPressure-Push am Radi nimmt man net den A12 sondern den P12.
Der A12 macht nur Sinn als zusätzlicher Pull.
Da braucht ein intelligenter Mensch net mal testen, sondern nur die Datasheets anschauen.
(2,34 vs 2,83 mmH₂O)
Pascal TM-Custom
Was heißt hier Humbug dann geh bitte zu Noctua und sag ihnen das ihr NF A 12 völlig Sinnlos ist für Radiator weil genau so wird er auch verkauft und genau so kaufen ihn viele als Radiator Lüfter denn dieser war als erstes da und wird überall als Referenz genommen.
Und es gibt schon einen Grund warum mehr und mehr Hersteller diese Blattform nehmen.
RX480
Und warum gibts dann überhaupt den P12?
da würde ich maximal vermuten, das überteuerte A12 an den Mann gebracht werden sollen
... von unwissenden Marketingleuten bei Noctua, verzapft
Pascal TM-Custom
wir haben eben verschiedene Radiator Größen/ Dicke wenn ich jetzt von Anfang an weiß ich werde einen 60er Radiator verwenden sollte ich vielleicht einen Lüfter nehmen mit mehr Druck der NF A 12 ist aber ein Allrounder und deswegen ist der die Referenz.
Pascal TM-Custom
daher direkt rufen Humbug ist Fail weil wir machen uns schon Gedanken welcher Lüfter als Referenz passt deswegen wurde bei der 140er Reihe der FLX vom NB abgelöst. Weil es da einfach mehr Sinn macht und bei 120er macht es Sinn einen Allrounder zu testen der sowohl als Case und Radiator Lüfter gut performt und dazu noch eine vergleichbare Drehzahl hat mit anderen und die liegt bei um die 2000 RPM.
Das es dann so Hornissen gibt wie der Rise der über 2500 macht ist dann etwas anderes aber denk mal logisch nach macht es jetzt Sinn einen Lüfter mit 1700 antreten zu lassen gegen die meisten die 2000+ machen? ich glaube nicht.
Solche Aussagen sollte man dann einfach lassen weil wir schon wissen was wir tun
Und unsere Tests haben wohl eindeutig gezeigt das Datasheets nix zu sagen haben oder irre ich mich?
J
Javeran
Wie sich der P12 redux 1700 PWM schlägt wäre aber trotzdem mal interessant. Der hat auch schon ein paar Jahre auf dem Buckel und ist doch relativ günstig zu haben.
Pascal TM-Custom
auch diesen hab ich da liegen ich versuch immer eine Mischung zu machen mal 140 mal 120 und manchmal kommen neue Lüfter raus die unbedingt getestet werden müssen da sie wie z.b jetzt der Rise rausstechen. :) ihr bekommt alle das was ihr wollt :D
w
wontiii
5 Kommentare 1 Likes
gibts nur noch den Arctic, welcher für mich im 1000RPM Bereich besser performt...wohl gemerkt auf einer Mora.
Hatte die Corsiar QL120, NB eloopX und zu guter letzt die Alpha Cool.
Die Arctic laufen einfach am stabilsten in Sachen Geräuschkulisse (niedrige Frequenz) und vor allem die Stabilität des Korpus waren hier deutlich besser, in meinem Use Case.
RAZORLIGHT
360 Kommentare 266 Likes
Ähm steh ich auf dem Schlauch?
Das betrifft doch die Merhheit der Radiatoren, der kommt in den Deckel und die Lüfter hängen ausblasend dran.
Sollte das Probleme bei einem Radiatorlüfter machen wäre das mMn. ein Designfehler.
Dennoch interessante Lüfter, leider musste Alphacool bei dem RGB Anschluss wieder ein eigenes Süppchen kochen.
Pascal TM-Custom
es ist tatsächlich so das es Lüfter gibt die das über Kopf verbauen nicht so mögen und dort ein klackern auftauchen kann oder andere Geräusche ich hatte mal Cooler Master mir ist jetzt nur nicht mehr bekannt welche das waren die haben im Normalen verbau sprich Senkrecht bestens funktioniert oben im Deckel aber haben die geklackert.
Es kommt auf das Lager drauf an.
mit dem RGB Anschluss joar Corsair,TT usw sind da net anders Alphacool hat bei ihren Produkten wie Eisbär usw diese Adapter dabei liegen nur nicht bei Einzellüfter. Das gute ist man kann die Lüfter Kaskadieren also muss man nur 1 Adapter kaufen. Klar man könnte es wie NB machen und zu jedem Lüfter einen beilegen aber ist das Umweltfreundlich? 1er wird benötigt und rest kommt in Müll.
Aber das kann jeder sehen wie er will :)
igor'lLAB Community
