Cooling Reviews Watercooling
Alphacool Eisbaer Aurora HPE 360 LT in test – flat, expandable and with copper radiator
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
Today, as announced, we are still testing the LT variant of the Eisbaer Aurora HPE, which offers a different design of the pump block. Thus, the flat form factor is more in line with what you are used to with a complete water cooling system. The rest of the features like the new copper radiator and fan remain with us. So let’s see if and what difference the other setup makes.
This article is very similar to the previous one, which can be read here:
Alphacool Eisbaer Aurora HPE 360 Review – Expandable AiO with new copper radiator | Launch
The familiar portrait-format cardboard box also protects this water cooler during transport, but sets itself apart from the full black printed packaging of the normal version with a white design. The smaller pump block is proudly presented at the front, the back is then shared by a picture of the fans, the radiator and the specifications.
The additional protective casing made of dense cardboard inside the box is identical to the normal HPE and offers quite a bit of resistance to impacts during transport.
The accessories are as extensive as they are small. Once we have the obligatory mounting material for all current sockets, an ARGB controller with knobs, 3 fan Y-cable as well as a tube of “Subzero” thermal paste. An adapter for the proprietary RGB connector is also included.
Having all the necessary brackets and screws in separate bags each with labeling is of course immensely helpful with this many small parts, but I would still prefer to see fewer plastic bags overall.
Assembly and installation
This water cooler once again relies on the backplate included with the motherboard for the AM4 socket. In addition, there are all the small parts mentioned, the following graphic shows the scope of this undertaking:
After everything is prepared, you still need to tighten the four screws crosswise. By the way, you should not be deceived by the size of the included tube of thermal paste, it is not completely filled. The content is enough for about two times use, possibly three if applied very sparingly. It is also somewhat tougher than, for example, the well-known MX-4 paste.
Specifications
Here is the overview of the technical details of the pump and fan, more information and a complete data sheet can be found on the product page at the manufacturer.
Megaone
1,876 Kommentare 1,791 Likes
Hallo Igor,
Kann man eigentlich bei diesen Waküs von Alphacool im Schadensfall problemlos CPU Kühler mit Pumpe wechseln oder hab ich dann einen Totalschaden?
ric84
63 Kommentare 30 Likes
So oft ich Tests usw zu AiO's sehe, aber irgendwie hab ich immer noch Schiss so ein Teil zu verbauen, weil ich vermutlich die eine von 1 Mio erwische, die während des Betriebes auslaufen wird 😂
Alphacool
368 Kommentare 534 Likes
@Megaone
Alle Teile sind austauschbar. Die Kühler-Pumpeneinheit gibt es auch als Solo Variante ohne Schläuche, Schnellverschlüsse und Radiator. Alle weiteren Teile kommen aus unserem normalen DIY Bereich und sich ebenfalls alle austauschbar. Selbst die Pumpe gibt es auch einzeln zu kaufen weil wir diese in diversen Systemen verwenden.
ipat66
1,496 Kommentare 1,550 Likes
Guckst Du da....:)
RAZORLIGHT
364 Kommentare 274 Likes
Danke für die Kritik an der Garantie ist für mich ein Dealbreaker.
Megaone
An dieser Stelle danke für die schnelle Auskunft. Aus meiner Sicht eine tolle und durchdachte Alternative zu den ganzen One-Way Kühlungen vom Wettbewerb die auch nicht erweiterbar.
Gut gemacht!
Megaone
Spannendes Produkt. Leider hat der Hersteller bei sehr vielen Produkte sehr lange Lieferzeiten. So auch hier.
ipat66
Ist lieferbar (Mindfactory)...:)
garfield36
1,293 Kommentare 337 Likes
Für User die vielleicht alle 4 RAM-Steckplätze nutzen wollen ist diese AiO nicht zu gebrauchen. Ein Hinweis darauf, dass der Steckplatz nächst zur CPU durch die Schläuche blockiert wird, wäre schon angebracht gewesen. Oder habe ich einen solchen Hinweis überlesen?
RedF
5,114 Kommentare 2,928 Likes
Kannst auch um 180° gedreht einbauen ( 90° sollte auch gehen ).
War aber die Hölle bei der alten LT die halterung wieder ab zu bekommen. : )
C
Cat Left
77 Kommentare 26 Likes
Wenn ich mir das Bild so anschaue sollte man selbst mit High profil ram keine Probleme bekommen.
Und eine gedrehte Montage ist auch noch möglich. Ich sehe also nirgendwo Anzeichen das es Probleme mit dem Ram geben könnte.
Übersehe ich was ?
Alphacool
@RedF
Die Klickhalterung wurde etwas überarbeitet. Das sollte bei Modellen ab diesem Jahr eigentlich viel leichter gehen, außer man hat noch eine Lagerleiche abbekommen. Bei den Alten ging es in der Tat wirklich schwer.
Tim Kutzner
888 Kommentare 730 Likes
Das wird nicht erwähnt, weil es kein Problem ist. Und wie @Cat Left schon richtig sagte, kann man den Block ja auch immer einfach drehen.
Tim Kutzner
@RedF Kann ich so bestätigen. Bei der normalen HPE waren die Halterungen etwas schwierig anzubringen, aber ab war ohne Mühe möglich.
Bei der LT ging beides ohne Probleme
Tim Kutzner
Ist doch lieferbar? :)
x
xavyer.keiren
25 Kommentare 5 Likes
Die letzten AIO hat man verrissen bzgl. Schmodder im Inneren.
Hier hätte man auch mal einen Blick riskieren dürfen, besonders auch mal einen Blick auf den Kühleraufbau von innen.
Irgendwie drückt sich jeder in den Reviews davor hier einfach mal die 4 Schrauben der Bodenplatte auf zu drehen.
garfield36
Wenn man die Fotos genau ansieht, ist wohl zu sehen, dass ein RAM-Steckplatz blockiert wird. Um 90° drehen wird auch nicht zu empfehlen sein, wenn das richtige Fenster oben sein soll. Da soll ja auch eine Richtung empfohlen sein. Und ich bezweifle auch, dass eine Drehung um 180° möglich ist. Aber dazu kann sich ja Alphacool äußern. Aber warum hätte Igor dann nicht den Pumpenblock um die besagten 180° gedreht?
Ich bleibe dabei, die Blockade des RAM-Slots dürfte einfach nicht sein.
Martin Gut
8,124 Kommentare 3,832 Likes
Wenn ich mir das genau ansehe, schätze ich, dass es geht, wenn auch knapp. Der abgewinkelten Schläuche gehen über die Spannungswandler, aber nicht über den Slot. Je nach Board kann aber natürlich sein, dass man die Pumpe nicht so einbauen kann.
Ich verstehe nicht, warum man die Pumpe nicht drehen können soll wie jeden Kühler. Man baut es so ein, wie es mit den Schläuchen am besten aufgeht und wie es gut aussieht.
garfield36
Ich hatte schon eine Alphacool. Da wird in der Tat vorgegeben in welcher Richtung sie eingebaut werden soll.
Tim Kutzner
Supporting force on cooler, periphery and 3D printing arcticles.
Linux novice and wanna-be datahorder with DIY NAS.
