Cooling Latest news Watercooling
Alphacool expands portfolio with active backplates for many Geforce RTX 3080 and RTX 3090 graphics cards
Disclaimer: The following article is machine translated from the original German, and has not been edited or checked for errors. Thank you for understanding!
Alphacool today announced its first proprietary active backplates for Geforce RTX 3080/3090 graphics cards. According to the manufacturer, the Eisblock Aurora GPX-N Acrylic Active Backplate is the perfect upgrade for Alphacool’s Eisblock Aurora Acrylic/Acetal GPX-N GPU custom water cooler as well as for Alphacool’s Eiswolf 2 GPU all-in-one solutions. With the help of the backplate, the graphics memory on the back of Geforce RTX 3090 graphics cards can now also be actively water-cooled. With the help of 7W/mk thermal pads, the active backplate has direct contact with the graphics memory to be cooled and can cool it even more efficiently. This should lead to a significant increase in cooling capacity.
Like all products from Alphacool’s Eisblock Aurora GPX acrylic product line, the active backplate features eye-catching lighting. Six digitally addressable RGB LEDs are integrated directly into the cooler. The effect is lighting that encompasses the entire cooling block and creates unique lighting effects. The digital aRGB LED lighting is connected via a JST-3 pin connector and can be controlled with a digital RGB controller or a digital RGB capable motherboard.
The technical data and compatibility list is shown in the data sheet:
PR_DE_03.02.22
Source: Alphacool
C
City1744
7 Kommentare 1 Likes
Hallo der Zusatzartikel (Alphacool's MCX 2x Verteiler) der im Artikel verlinkt ist, gibt es nicht auf Alphacool- Zumindest führt der Link ins Leere
Ben87
149 Kommentare 34 Likes
@Alphacool Auch wenns unnötig ist, wird sowas auch für die RX 6000er Kommen?
Alphacool
368 Kommentare 534 Likes
@Ben87
Nein, für die aktuelle AMD Generation werden wir das nicht anbieten. Wie du ja sagst, es ist unnötig. Sicher gibt es einige die es dennoch kaufen würden, aber wir schätzen die Nachfrage als gering ein. Auch weil.... und das werden AMD Fans ungern hören, es ist aber einfach Fakt... die Nachfrage nach AMD Wasserkühlern entspricht nur einem Bruchteil gegenüber Nvidia Modellen.
@City1744
Sorry, kann sein das wir im PR-Newsletter einen Fehler im Link hatten den wir übersehen haben. Das ist der Verteiler: https://www.alphacool.com/detail/index/sArticle/29620/sCategory/20538
Ben87
@Alphacool
Ja kann ich mir vorstellen! Gegen das aggressive NVIDIA Marketing hat AMD keien Chance :-D
Aber danke für die Info!
Dann bis RDNA 3 ;-)
k
krelog
174 Kommentare 53 Likes
@Alphacool ist schon klar wann sie verfügbar sein werden?
und zu dem MCX2 Verteiler hängt der einfach parallel im Kreislauf oder wie wird da ein gewisser Durchfluss sichergestellt
Alphacool
@Ben87
rein subjektiv gefühlt, sind Wasserkühlungsfreunde eher auf Seiten der Nvidia Freunde zu finden. AMD Freunde scheinen .... und das ist eine rein persönliche Meinung... eher praktischer veranlagt zu sein. Sprich, einbauen, spaß haben, fertig. Bei Nvidia Freunden hat man eher das Gefühl, die Leute spielen gerne mehr herum.
@krelog
Es ist doch alles verfügbar, oder was meinst du jetzt speziell?
Der hängt paralell im Kreislauf. Allerdings funktioniert der nicht mit der Eiswolf AIO. Man braucht einen gewissen Durchfluss damit der sauber arbeiten kann. Die AIO erzeugt nicht genug Durchfluss. Da braucht man ein bisschen mehr Druck. Bei einer normalen DIY Kühler wird es hier keine Probleme geben. Zumindest konnten wir in keinem Test ein Problem feststellen.
k
krelog
sorry mein Fehler wo ich vorhin geschaut hatte stand nciht verfügbar da jetzt daheim kann ich bestellen war wohl noch was falsches im Cache
Danke für die Info zum MCX2 da werde ich wohl ehr auf die 1/8" Anschlüsse gehen
Oryzen
314 Kommentare 184 Likes
Ist das so? Oder liegt es an den lauten Düsentriebwerk-Lüftern der Karten, die die Leute einfach ruhig stellen wollen? Oder dass die wie Heizstrahler auf die restlichen Komponenten wirken... selbst ohne Overclocking...
Was wäre denn dann die Empfehlung für ein leises, kühles Nvidia RTX 3090 System mit aktiv gekühlter Backplate? z.B Zotac. Der Alphacool-Konfigurator bietet da noch nichts mit Backplate, und AIO wäre ja auch als Variante mit separater Pumpe denkbar.
:unsure:
Ben87
hmmmm frag doch mal Alphacool hier im Forum. Kann mir vostellen, dass für deine Zotac auch noch eine aktive Backplate kommt. Den GPX Block gibt es ja schon.
RedF
4,850 Kommentare 2,693 Likes
Wird eher daran liegen das viel mehr NV karten wie AMD verkauft werden.
m
mibraa
43 Kommentare 28 Likes
Für die 3090 Zotac ohne "Holo" kannst den nehmen.... https://www.alphacool.com/shop/graf...-n-acryl-active-backplate-3090/3080-reference
Bin am überlegen das Teil anzuschaffen.... aber mit 78 Grad ist der Speicher eigentlich nicht zu heiß...
@Alphacool: könnt ihr Igor son ding zukommen lassen, damit er den testen kann?
Sofern er Zeit findet dafür...🤯🥵
Oryzen
@Alphacool: ich habe die Backplate schon gefunden, aber kein System im Konfigurator MIT Backplate. Wird das noch nachgepflegt? Und was wäre die Empfehlung für ein leises System, von mir aus dann mit CPU (AMD5950) im Kreislauf. Klar kann ich mir selber was zusammensuchen, aber warum nicht mal hier fragen? BlinkiBlinki muss nicht sein, ich lege Wert auf eher schlicht, schwarz, dunkel und STILL.
Tips sind wilkommen...
Saschman73
500 Kommentare 298 Likes
Das ist sehr schade! Ich hätte zugeschlagen und meine 6900XT gepimpt! :cautious:
F
Fonsa
60 Kommentare 54 Likes
Gibt's auch eine Kühler mit aktiver backplate für die 3090 Founders?
Ben87
ja. Geh mal auf die Alphacool Homepage in den Shop!
F
Fonsa
Nö, da seh ich jetzt keine mit aktiver backplate für die founders.
Schade eigentlich.
Ben87
Doch schau mal genau! GPX Block und die Backplate mit aktiver Kühlung. Geh auf GPU Konfigurator
Kurbalaganta
35 Kommentare 14 Likes
Ist ja hier kein Verkaufsberatungsforum. Das findest Du hier. Öffne da einen Thread.
Aber eine GRUNDSÄTZLICHE Empfehlung für ein leises System lautet: Radifläche. Radifläche und noch mehr Radifläche :giggle:
Follow Igor:
