Cooling Fans Latest news
Alphacool Apex Stealth Metal (Power) fan now available for pre-order in 8 variants – Review will follow tomorrow
Today’s unveiling of the Alphacool Apex Stealth Metal Fan (Pro) completes the circle of long development, various pre-announcements and influencer pirouettes, as the part has finally arrived in mass production and is also now available for pre-order. Of course, we live in a time where even a trivial new screw cries out for attention by splitting the product release into left-hand and right-hand threads and also presenting the respective colors individually.
At least Alphacool spares us this media circus, even if it still takes a while until the final delivery. The reasons lie in the new design, which requires completely different conditions for production than those of conventional fans. But Alphacool is at least serious as of today and I may also spoil that a large part will be manufactured in its own factory, which Alphacool has built up in China in recent years.
But let’s get back to the fans. Initially, the fans will be available as 120 mm fans in the colors chrome, gold, white and matte black, but due to the special coatings of the metallic frame, many other colors are also envisioned and feasible. The fans will also be available as normal and Power variants, with the difference limited to the maximum speeds increased from 2000 rpm to 3000 rpm. The rest is the same.
But I will of course be able to write much more about this in the review, because I have also examined the material. Last but not least, Alphacool relies on a very low-vibration 6-pole motor in the impeller with the 9 rotor blades, so that in total a truly novel product was created, which can shine with very low noise emissions at high volume flow and static pressure. Since we were able to test these fans again and again in the run-up and thus also had a good insight into the development phases, I may antease the article including many further details today. Depending on the amount of text, the full review will be published tomorrow (or Tuesday at the latest), including the entry in our fan database.
However, I will of course be able to write much more about this in the review, since I also examined the material. Last but not least, Alphacool relies on a very low-vibration 6-pole motor in the impeller with the 9 rotor blades, so that in total a truly novel product was created. Since we could mssen these fans in advance again and again and thus also had quite a good insight into the development phases, I may anteasern the article including many further details today. Depending on the amount of text, the complete review will be published tomorrow (latest on Tuesday), including the entry into our fan database.
And I may already spoil once that I looked at the fans not only once in amazement to check if they are really still running. And these are the first fans where we also reached the limits of the equipment and our premises in terms of evaluating the noise emission in the range of startup speeds. The diagrams shown today are from Alphacool’s marketing material, and of course the rest can be found in the article:
The fans are available for pre-order from the usual suspects and, of course, Alphacool itself for around 30 euros starting today at 13:00, with the power variant with the 1000 rpm more on the speedometer costing no extra. Of course, not every user will need the entire speed range, so the normal variant can be regulated as usual and thus fits perfectly to the preset fan curves of almost all motherboards without any reworking in the settings. If you like it stormier, you are welcome to use the power version, so today’s pre-order starts with a total of 8 fans and there should be something for everyone.
Apex-Stealth-Metal-Fan_Info_PDF_EN
Revolution in the case fan market: Alphacool Apex Stealth Metal (Power) Fan in an exclusive review
ianann
338 Kommentare 235 Likes
Um es mit Geralts Worten zu sagen: "Hmm ..."
Pascal TM-Custom
1,122 Kommentare 1,361 Likes
Morgen wird es heißen uiiiiiiiiiiiii.... :D
Tronado
3,952 Kommentare 2,086 Likes
Alphacool hat den seit 120 Jahren gebräuchlichen Lüfter neu erfunden, cool.
Und die bringen uns als Gehäuselüfter jetzt 3°C geringere Temps bei GPU und CPU? Ich denke nein.
Der Hersteller freut sich aber bestimmt sehr über das Vorab-Marketing.
Pascal TM-Custom
leiser mehr druck mehr Flow?
Gibt wohl sicher auch andere Einsatzzwecke wie z.b Radiator.
Ich mag mich noch Erinnern das du meintest Lüfter muss leise sein. Bei dem Lüfter hörst eben so gut wie nichts da er sich mit 2000 RPM anhört wie bei 1000 RPM bedeutet hast mehr Flow mehr druck bei Minimaler Geräusch Entwicklung.
Antwort 4 Likes
10,484 Kommentare 19,645 Likes
Das wird Einiges auf den Kopf stellen, das kann ich Dir jetzt schon versprechen. Die anderen werden Nachziehen müssen, das wird eine Demütigung mit finalem Nackenschlag. Dazu gibt es morgen satte 2 Seiten Theorie und Messungen außerhalb der Kammer.
Antwort 11 Likes
Tronado
ich bestelle mir mal einen, dann sehe/höre ich es ja selber. Leiser als die P14 ARGB war bisher noch nichts.
Pascal TM-Custom
es kommt ja noch eine 140er Version
Antwort 4 Likes
Y
YoWoo
41 Kommentare 21 Likes
Bin echt gespannt! Noch ein ruhiges WE.
Lärmbolzen. :D
Ich habe einen der Stealth hier direkt neben mir auf Fullspeed am Benchtable um die VRM und den RAM zu kühlen. Ich höre alles, nur den nicht :D
Sogar Linus war fast eine Stunde auf der Computex am Stand und hat nicht mal Geld fürs Video haben wollen. Nur einen Lüfter :D
B
Beschi
47 Kommentare 9 Likes
Moin,
Das "lediglich" ein steifer Rahmen so viel bewirkt ist schon erstaunlich. Ich bin gespannt wie die anderen Hersteller darauf reagieren.
Gruß Beschi
Es ist NICHT nur ein steifer Rahmen. Morgen gibt es dann die passende Thorie dazu. Selbst der mit 3000 rpm ist noch erträglich und man hört in erster Linie die Abrissgeräusche, also die Luftwirbel, aber kaum den Motor. Unter 1500 rpm muss man echt hingucken, ob der noch an ist :D
ianann
Das lauteste an halbwegs wertigen Lüftern auf Radiatoren oder vor/ hinter Lüftergittern etc. ist doch eh nicht der Lüfter an sich, sondern Strömungsgeräusche an allem was dem Luftfluss vorher oder nachher im Weg steht, oder nicht?
Megaone
1,833 Kommentare 1,724 Likes
Alpha gehört in positiver Hinsicht zu den bemerkenswertesten Herstellern der letzten Jahre. Freue mich auf den Test.
Andy197
196 Kommentare 96 Likes
Hab's bei Alpha schon auf der Homepage gelesen und hoffe für uns und Alpha selbst, dass diese Werte stimmen. Das wäre ein jenseits Schlag ins Gesicht für Noctua und alle anderen "Premium" Hersteller. Ich muss leider noch auf die 140er warten, da ich die 120er nicht mehr brauche :D
Gibt es eigentlich auch Tests der Lüfter auf den Radiatoren zwecks Luftgeräusche durch verwirbellungen?
Pascal TM-Custom
Nein ist nicht nur die bewegte Luft da spielen die Lager, Motor, Abrisskante etc etc mit rein.
Pascal TM-Custom
auf Morgen warten ;)
Dann vergleichst die Werte von Alphacool und unseren dann fällt dir etwas auf :D
big-maec
916 Kommentare 541 Likes
Das Gewicht der Lüfter ist aber auch nicht zu verachten, wenn ich 10 Lüfter im Lian Li Gehäuse verbaue sind das stolze 3,2KG. Mein Gehäuse hat jetzt schon ein stolzes Gewicht, wenn das noch obendrauf kommt, hätte ich wohl einen der schwersten PCs.
Pascal TM-Custom
bau das mal ins Obsidian 1000D mit Push Pull :D
hoffe das die Person dann einen Lastenaufzug besitzt und die Türe Groß genug ist fürn Gabelstapler.
ianann
Interessant ist auch, dass mit einem 120er gelaunched wird.
Hätte ehrlicherweise erwartet, dass 2023 unterdessen 140er deutlich verbreiteter sind.
Follow Igor:
