CPU Latest news
AGESA ComboAM5 1.0.7.0 for AMD’s Ryzen 7000 in detail: memory management and an important update of the protection features against overheating
AMD has announced that they have been able to identify the cause of the defects in their Ryzen 7000 processors. In a Statement to Anandtech the company stated that the issues are due to excessively high voltages that are outside of the intended specifications. In response, motherboard manufacturers have received an updated AGESA version, whose version number is COMBOAM5PI 1070. This new version will soon be integrated into BIOS updates for all AM5 mainboards and will contain lots of new features and also bug fixes. Among other things, it should ensure that the AM5 CPUs can’t take SoC voltages of more than 1.3 volts to prevent the CPUs from the burnout that just became public.
The company has also emphasized that the new AGESA version should not affect the operation of RAM overclocking via the EXPO function. This is quite remarkable, since exactly this function has been responsible for the increased voltage on many motherboards so far. Also in the ChangeLog available to me, the abbreviation RPL (Raphael) does not exclusively refer to the X3D series, which is then called RPLX3D when it becomes exclusive. Thus, AMD also confirms in the new ChangeLog that all current processors of the 7000 series were affected by the said defects. I have exclusively filtered out the most important changes in the ChangeLog for you and deleted the rest. RPL stands for Raphael, RPLX3D for the X3D processors and PHX or PHX2 for Phoenix. Even though it’s primarily about Raphael, i.e. our well-known Ryzen 7000, I’ve also selected a part of the entries for Phoenix and Phoenix 2, because they still hide very interesting information.
Memory management and boot times
For example, there is a lot in the log under PMM for the post memory manager. Overall, it’s noticeable that a lot revolves around the memory, which also provides a credible basis for AMD’s announcement about the memory. This goes to DRAM tracing, which refers to the process of collecting and analyzing data related to the use and performance of DRAM in the computer system. DRAM tracing can be used to monitor memory system performance, identify potential bottlenecks or problems, and improve overall system efficiency. DRAM tracing can also help identify errors or incompatibilities in memory modules or memory controllers and provide appropriate solutions or optimizations.
Safety features for CPU operation and better overheating protection
The entry FWDEV-38540 for the Safe mechanism for RPL-X3Das well as some points about the Deep Sleep. However, it becomes even more interesting with the entry FWDEV-39317 for all Ryzens of the CBS SMU_COMMON ‘PROCHOT Control’ and and ‘PROCHOT Deassertion Ramp Time’ for all Ryzens. Since this is a very interesting point and is directly related to overheating, I will explain it briefly. CBS (Core Performance Boost) is a feature implemented in many modern processors, especially from AMD, to automatically boost CPU performance when needed. The term “SMU_COMMON” refers to the System Management Unit, which is responsible for managing and controlling the performance, power and temperature in a computer.
PROCHOT (Processor Hot) Control is a function related to CBS and SMU_COMMON. It is a thermal safety function used to protect the processor from overheating. When the temperature of the processor reaches a critical value, the CPU or another system component sends a PROCHOT signal, whereupon the processor reduces its power to lower the temperature and prevent possible damage. CBS SMU_COMMON ‘PROCHOT Control’ therefore refers to the control and management of the PROCHOT function within the System Management Unit and Core Performance Boost system to ensure that the processor is operating both efficiently and safely.
PROCHOT (Processor Hot) Deassertion Ramp Time is a time specification that describes how long it takes for a processor to increase its power again after the PROCHOT signal is disabled. PROCHOT is a thermal signal sent by the CPU or other components in the system when the temperature reaches a critical value. In such situations, the processor reduces its power to avoid overheating and possible damage. When the temperature drops back below the critical value, the PROCHOT signal is disabled. The Deassertion Ramp Time indicates how long it takes for the processor to gradually increase its power and return to normal operating conditions. This time can vary depending on the processor model and specific system requirements.
Especially the entries about PROCHOT suggest that a lethal cocktail of different factors might have occurred here. On the one hand there are the too high voltages and on the other hand the possibly not perfect thermal management. What looks quite pleasing are all the entries around the memory, from the boot time up to the DRAM tracing. From this point of view, every user of a Ryzen 7000 CPU should watch out when the board manufacturer provides a suitable BIOS and then flash it immediately.
Source: own
207 Antworten
Case39
2,550 Kommentare 965 Likes
Das hat aber nicht lange gedauert, bis AMD entsprechend reagiert...je nach dem, wie man es sieht.
P
PaRaPheeniX
9 Kommentare 1 Likes
Also kann ich dann expo ab der nächsten agesa version bedenkenlos nutzen? Versteh ich das richtig
Case39
Ja, das sollte wieder möglich sein...aber trotzdem mit Vorsicht.
F
Furda
663 Kommentare 373 Likes
Tolle Sache wenn man Zugriff auf das detaillierte Changelog hat, tiefe und interessante Einblicke, welche man als User nie zu sehen bekommt, ausser dem kurz und knappen "improvements" bei "dies & dem" im öffentlichen Changelog. Schade
Antwort 4 Likes
Guest
AMD wunderts ich dann warum nach zig jahren immer so schlechten ruf hat.....wie wärs mal nicht Beta Produkte zu releasen, nur einmal?
Case39
Das sollte für ZEN5, Hoffnung geben...
c
cunhell
562 Kommentare 529 Likes
Als ob andere immer fehlerfreie Technik liefern würden. :rolleyes:
Cunhell
10,484 Kommentare 19,647 Likes
Das mit dem "Zugriff" ist das Hegen und Pflegen von internen Quellen, die mir immer genügend Wasser auf die Mühlen des medialen Daseins garantieren. :D Es wäre schöner, wenn es auch offiziell ginge, aber da muss man schon selbst aktiv werden :)
Antwort 7 Likes
c
cunhell
Da zahlt sich eben auch aus, dass Du Deine Quellen schützt, in dem Du nur soviel von Deinem Interna-Wissen preis gibst, wie es gefahrlos möglich ist. Einfach klasse (y)
Cunhell
Guest
Weder hatte ich bei Nvidia solche Probleme mit Gpus also JEMALS und jede Ryzen Launch hat irgendein Problem was man immer gut in den Hardware news nachverfolgen kann. (wobei ich da immer glück hatte, hat immer funktioniert bis jetzt, bis auf das nervige verhalten von Zen 2).
Das hier jetzt ist schon echt schlecht für das Image die Statements sind auch nicht gut meiner Meinung nach. Kann doch nicht sein das man sich eine Sau Teure Plattform kauft und dann sowas befürchten muss? Gott sei Dank habe ich mich für AM4 entschieden ^^
Unrockstar85
38 Kommentare 23 Likes
Das ist doch die Untertreibung des Jahres..
Hast du dir eig mal die Sachlage dazu angeschaut. Also zu behaupten, die anderen Träfe es nicht, ist ein starkes Stück und fast schon eine Realitätsleugnung.. Wir reden von einer Dead Quote um 0,02%, das ist in Fachkreisen nicht mal RMA würdig und nur der Medialen Berichterstattung geschuldet.
Faktisch sagt das Log aus, dass die CPU mit ZeroFan Modi massive Probleme hat, da man hier schnell zur Überhitzung neig. Die hohe, durch hier Asustek und Gigabyte, gelieferte SoC Spannung trägt dann dazu bei.
Warum nochmal hat es MSI nicht betroffen? Vermutlich, weil die die fähigeren Ingenieure haben.
c
cunhell
Sorry, aber ich fange jetzt nicht an, die Ganzen Hardwareprobleme der anderen Hersteller rauszusuchen um sie mit Links zu untermauern.
Was soll an den Statements schlecht sein. Sie haben den Fehler wohl gefunden und liefern zeitnah eine Fix. Die Betroffenen sollen sich bei AMD melden um Hilfe zu erhalten. Was sollen sie denn noch schreiben? In dem Statement steht alles Relevante drin. Ausschmücken muss man da nun wirklich nichts. :rolleyes:
Cunhell
Guest
Weiß nicht zu den Gpu problemen bei Amd finde ich wesentlich mehr bei AMD, obwohl Nvidia 10:1 mehr verkauft. Damit dürfte das ja erledigt sein ;). Trotzdessen sind das auch meine eigenen erfahrungen gewesen :) .
Das dieser Post in einem Sub wo nur Fanboys sind positiv bewertet wird spricht bände gerade auf Reddit.
RDNA3 Idle energieverbrauch ist immer noch nicht gefixt und wird es auch niemals. (n) Das geht ja gar nicht.
Aber gut egal hoffe mal das hier niemanden die cpu abfackelt😬:)
T
TheSmart
432 Kommentare 216 Likes
Naja....sorry aber das liest sich jetzt wie ein Nvidiafanboy..
Der völlig ausblendet, das eine 2000 Euro Grafikkarte von dem besagten Hersteller sehr schnell angebrutzelt hätte werden können.. durch die völlig verpfuschten 12-Pin-Anschlüsse.
Denn die kommen zwar von einem Dritthersteller, aber es lief alles im Auftrag von Nvidia ab..aber da gab es wohl keinerlei QM.
c
cunhell
Das Du zu den AMD-GPU-Problemen mehr bei AMD findest als bei Nvidia ist ja logisch. Warum sollte man bei Nvidia etwas über AMDs GPU-Probleme finden.
Ich habe seit jahren nur AMD/Ati-Karten und keine Probleme. Und jetzt?.
Ich wiederhole mich: Ich habe seit jahren nur AMD/Ati-Karten und keine Probleme.
Ausserdem kenne ich einige die ebenfalls AMD-Karten haben und keine Probleme feststellen.
Was sagt das jetzt aus?
Und? Ist ein Bug der gefixed werden kann oder nicht. Ist nicht schön aber ggf. der neuen Architektur mit Chipletdesign geschuldet.
AMD sind nicht die Ersten und auch sicher nicht die Letzten die Bugs in Hardware haben, die man nicht zwingend fixen kann.
Es gibt sogar Erratas von den Herstellern, die zum Teil sehr umfangreich sein können, die diese Bugs auflisten.
Bei der Verkauften Menge an CPUs und Boards ist die Gefahr offensichtlich nicht so riesig wie es jetzt hier z.T. dargestellt wird.
Die Plattform gibt es zu lange und zu wenige Fälle als dass man hier jetzt paniken müsste.
Cunhell
Zur werten Kenntnisnahme:
Hier geht es um RYZEN und nicht im Pixelschubsen :)
Antwort 4 Likes
c
cunhell
Ich weiss das. Ich habe nicht mit dem Hersteller mit dem großen "N" angefangen.
Cunhell
grimm
3,193 Kommentare 2,125 Likes
Man muss halt auch mal sagen, dass es dabei um OC-Einstellungen (EXPO) geht. Und auch wenn alle so tun, als ob man problemlos mit drei Mausklicks 10% mehr Leistung hat, bleibt das heikel. Betreibst du die Hardware ohne die entsprechenden Profile, scheint es ja keine Probleme zu geben - guck dir die Quote an. Hier jetzt einen Rant rauszuholen und die alte Leier von AMD gegen Nvidia gegen Intel zu spielen... :rolleyes:
Veii
186 Kommentare 212 Likes
Thank you ! ~ AMD™
Und danke Igor :)
Follow Igor:
