CPU Latest news
Added: AMD’s Ryzen 7000 "Raphael" desktop CPUs allegedly with maximum frequency limit of 5.85 GHz
Last week, AMD announced a few more details about its Ryzen 7000 CPU lineup, codenamed Raphael, and still corrected or corrected others. Thus, AMD confirmed that the TDP of its top Ryzen 7000 CPUs will actually be 170 W, while the maximum package power of the AM5 (LGA 1718) socket may even reach 230 W. The company also confirmed that the gaming demo shown at Computex 2022 was a 16-core prototype running at 5.5 GHz across multiple threads. It is also interesting that the prototype ran in a power consumption range below the new 170 W TDP specification.
So we know that the AMD Ryzen 7000 demo at Computex 2022 was not a single-thread clock speed showcase, and it wasn’t even a final prototype using the full 170W TDP spec. (Robert Hallock on Reddit)
Based on a report from Angstronomics’ sources, it really looks like there is an OPN (Evaluation Pattern) that could exist with a maximum frequency limit of 5.85 GHz. As far as the maximum clock frequency is concerned, the gaming demo, which at least showed 5.55 GHz maximum frequencies on one thread, was probably not the end of the line either. Angstronomics did report an order number (OPN) backed by a 5.85 GHz Fmax, but we’ll have to wait and see what value the stepping limits are set to later in the final versions.
But the 5.85 GHz is an insane clock, and considering that only a first look at a prototype AMD Ryzen 7000 desktop CPU was taken, the final specs could very well be in that range. A 16-core CPU that would use the full 170 watts might well be able to exceed 5.5 GHz and deliver clock speeds that we have never seen before in an AMD Ryzen CPU. Intel is aiming for similar clock rates with its Raptor Lake desktop CPUs, so it probably makes sense for AMD to compete with the blue team in the area of clock rates, where they have always been behind in the past few years.
We’re already looking forward to 5.5 GHz clock speeds for AMD Ryzen 7000 desktop CPUs, and anything above that would be a real treat for us consumers looking forward to building a brand new AM5 PC with the latest Ryzen 7000 desktop CPUs. Of course, such frequencies are only possible on the better AM5 motherboards, such as those based on the X670E chipset, which have plenty of VRMs to meet the performance requirements for the new Fmax specification. Unfortunately, the power still comes from fuel.
I had already pasted the data for Raptor Lake S a long time ago, which should hardly change in the end. Unless someone at Team Blue still gets cold feet in view of Zen 4.
Leistungsaufnahme, Lastspitzen und Technik-Details: Intels kommende Alder Lake S und Raptor Lake S CPUs im exklusiven Vergleich
Source @hjc4869 via Twitter
HerrRossi
6,811 Kommentare 2,256 Likes
Anscheinend kann man mehr Leistung nur noch mit mehr Stromverbrauch erkaufen. Keine gute Entwicklung.
Antwort 4 Likes
K
Kobichief
673 Kommentare 204 Likes
Och, wird sicher auch effiziente Parts geben. Das eine ist Marketing, das andere sind die CPUs die mann dann in großer Stückzahl verkauft. Über 5Ghz, DDR5, ?+IPC. Da werden deutlich größere Sprünge als die 15% drin sein. AMD dudes Kichern sich doch einen ab wenn die 15% erwähnt werden. Bei der Power wird auch die integrierte Grafik drin sein.
Meine bedenken sind eher bei der Kühlung.
10,459 Kommentare 19,561 Likes
Was ich so noch so gehört habe, aber leider keinen Beleg dafür veröffentlichen kann (es ist also eals Gerücht einzustufen), ist der Umstand, dass es sogar zwei OPNs mit 5.85 GHz geben soll, den 8 und den 16-Kerner. Also quasi Gold-CPUs für beide Optionen mit einem oder zwei Chiplets. Was wiederum wohl auch auf den Preis gehen könnte (X-Versionen). Allerdings sind diese hohen Taktraten auch keine Garantie für die Serie. Im Vorfeld wird immer auch in der Fläche getestet, was wie lange wie gut geht. Und damit noch stabil bleibt. Ich denke mal, die finalen CPUs werden wohl bei 5.6 GHz oder knapp drunter boosten.
Die 230 Watt fürs gesamte Package sollten aber gesetzt sein, die bereits kolportieren 125 Watt für die Single-Chiplet-CPU.
D
Deridex
2,223 Kommentare 858 Likes
Also ich finde diese neuen maximalen Verbrauchsangaben "gar nicht mal so gut" (kA wo ich das mal gehört habe, finde es aber lustig).
Casi030
11,923 Kommentare 2,339 Likes
Wenn man die iGPU mit rund 35Watt abzieht bleiben auch nur noch rund 195W und die werden sicherlich schwierig sein selbst mit 16Kernen ohne Eingriff Real zu erreichen,die rund 13Watt pro Kern sollten sich aber noch gut kühlen lassen.
Ghoster52
1,455 Kommentare 1,120 Likes
Naja, würde ich den 5900x (12 Kerne) saufen lassen, zieht der schon mal bis zu 200 Watt,
da sind 170 Watt bei 16 Kerne sympathischer....
Klingt weniger nach "Brechstange" :ROFLMAO:
Casi030
Deswegen ja ohne Eingriff , kommt halt drauf an wo TDC und EDC landen werden.
Thy
1,843 Kommentare 744 Likes
Ich freue mich schon auf die Bilder in Igor's sonntäglichen Beiträgen, in denen Ryzen 7000 zu sehen sind, bei denen sich die Wärmeleitpaste durch übermäßigen Gebrauch in die IHS-Lücken auf der Oberseite gequetscht hat. Frage: Wird die Oberfläche eher konvex oder konkav sein?
170 Watt Core. Fürs gesamte Package 230 ;)
ipat66
1,417 Kommentare 1,430 Likes
Die kolportierten Verbrauchswerte (170-230Watt) sind ja die Maximalwerte....
Ich bin gespannt,was Igor da noch herauskitzeln kann (OC und vor allem UV).
Die 5,5 GHz wurden ja unterhalb der 170 Watt erreicht und es handelt sich ja auch um die ersten Samples....
Interessant ist auch die im Gegensatz zu Intel,die voraussichtliche Unterstützung von Avx-512.
Abwarten und Tee trinken......
Casi030
60Watt für den SOC,was meinst,braucht DDR5 und PCIE 5.0 mehr oder weniger als DDR4 und PCIE 4.0 oder kennst die Einstufung der iGPU schon in welchem Watt Bereich die liegt?
Da der I/O-Chip in anderer Strukturbreite kommt, kann man hier nur spekulieren. iGPU mit Sicherheit <35 Watt, aber ich denke eher in Richtung 15 Watt für die normalen CPUs, denn das sind nur Sparbrötchen.
D
Deridex
Much würde es wundern wenn DDR5 und PCIe 5 sparsammer als DDR4 und PCIe4 sind.
Casi030
Auch war,35Watt für die iGPU wäre schon viel,das würde ja dann schon in die Leistungsklasse der iGPUs aller 5600G/5700G gehen.Wo würden dann die APUs landen?!
Wird auf jeden Fall Spannend.
D
Denniss
1,571 Kommentare 584 Likes
Vielleicht sehen wir den Namen "Black Edition" wieder für diese Hochtaktversionen. Wenn Intel 200+ Watt verballern kann dann schafft AMD das auch allerdings wohl mit entsprechend mehr Leistung.
K
Komposti
5 Kommentare 1 Likes
Hmm, weiß nicht so recht was ich davon halten soll. Einerseits sehe ich es ein, das bei einem neuem Sockel der vermutlich in Zukunft auch mehr als 16-Kern-Prozessoren beherbergen wird, auch die TDP entsprechend angehoben wird, einfach um mehr Spielraum zu haben. Auf der anderen Seite würde ich mir eher wünschen, die Entwicklung ginge mal wieder in die andere Richtung, allerspätestens seit Apple mit dem M1+ die versammelte Konkurrenz deklassiert hat.
Hohe Takraten gehen immer zu lasten der Effizienz und der IPC-Gewinn scheint überschaubar zu sein.
Aber gut, vermutlich können weder Intel noch AMD es sich leisten, derart verschwenderisch mit Transistoren um sich zu schmeißen wie die Apfelfirma.
Vermutlich hat AMD im Moment auch wenig andere Möglichkeiten, gegen Intel gegenzuhalten. Die sind sich ja nicht zu schade dafür in immer höhere Verbrauchssphären vorzustoßen und haben noch dazu inzwischen auch die mächtigeren Kerne.
Vermutlich wird das im Herbst aber kein einfacher Kampf gegen Raptor-Lake.
Aber man hat ja noch den 3D Cache in der Hinterhand.
D
Denniss
Ach der M1-Mythos wieder. In der realen welt sieht das schon wieder ganz anders aus, da ist der M1 zwar gut aber nicht so Über-Hyper-Gut wie manche ihn gerne sehen würden. Zudem ist er speziell auf seinen begrenzten Einsatzbereich entwickelt wogegen Intel/AMD eher Allzweckwaffen im Programm haben.
AMD Mendocino sollte im Low-Power-Bereich einiges leisten können obwohl der bei der Grafikeinheit wohl recht abgespeckt ist.
Casi030
Das liegt doch an jedem selber was seine CPU verbraucht.
SMT z.b. bring bei AMD nix , und wenn deine Anwendungen auch keine 32 Threads Auslasten können, dann stellt man SMT aus und verliert 0 Leistung in Spielen bei max 75Watt wie bei mir.So läuft mein R9 5950X, lediglich der Ram mit 3000MHz hat hier in manchen Spielen ein ticken zu wenig Bandbreite was mich in ein paar Benchmarks 1-2FPS kostet.Duch die Optimierung ist der Single Core aber dennoch höher als normal.
B
Besterino
6,893 Kommentare 3,465 Likes
Gibt's eigentlich vielleicht auch endlich mal was Neues im Hinblick auf die Anzahl der PCIE-Lanes (der CPU bitte) oder bleibt hier alles beim (dämlichen) Alten?
Follow Igor:
