Hi,
I'm trying to load BIOS saved from XFX 6800 XT Merc 319 Superspeed model but when I try to load previously saved .rom the RBE says it's not supported.
The BIOS has around 1MB, not 512kb as in some cases.
Is this lack of support model specific? Can I do anything else to lower GPU power consumption?
The card reports around 120W consumption but it's really @ 220W at the wall (260-270 for whole system).
Any hint, tips will be greatly appreciated.
Thank you
PS I used ATIFlash tool v 3.20 to extract the BIOS and also tried with GPU-Z latest version
I also tried the process with my other Sapphire 5700XT card without problem.
Thank you
