Hi!
I have some trouble in increasing the minimum voltage with MorePowerTools because the gpu crashes from time to time.
Tried to increase minimum voltage GFX and SoC to 850mv, flash resulting bios but without effect, it still shows me 830mv.
I am sure the workflow is correct because I can modify e.g. memory DPM3.
What is the right way to increase the minimum voltage for Rx5700XT?
By the way, I used the same bios for another RX5700XT, same brand, and the minimum voltage is higher.
Can someone please explain?
Regards,
Pubart
Regards,
Pubart
