N
nathan2225
Guest
Hello,
seeing a lot of expertise in the (AMD) graphic cards sector here, so I desperately will ask my question:
This card is running notourisly hot, and I would like to change this...
Is there a way to change the power target for this card?
Wattman (Radeon Pro software) seems to be unable to support this (als tried with MSI Afterburner)
I can see in the BIOS (Polaris BIOS Editor) data that there is a defined Power Control limit of 50% but I was unable to find a way to control the power limit
Is there any tool/patcher available out there which could do the trick?
Or is the only way to change the limit to patch the BIOS itself?
Thanks
Nathan
Thanks
Nathan
