A little help here!
13- Copy the frequencies and voltages under the diagram in the AMD Raedon software to the Stock voltage ports, please note that the frequencies in NaviCurveHelper are in GHz and not MHz, E.g.; 800 MHz = 0.800 GHz and the frequencies in the AMD Raedon software should be (800, 1120, 1440) MHz,
14- Now copy the same frequencies from AMD Raedon software to the Modded curve parameters in the NaviCurveHelper and enter the voltages in the Modded voltage ports, left 0.700, middle 0.700, right 0.800,
15- Now copy the Modded curve parameters, Curvature, Vertex and Offset from the NaviCurveHelper to the MorePowerTool ones under the Curve tab and Enable Override AVFS and Click Write SPPT,
