Hi guys i received some 5600xt thicc ii pro 14gps card which all have being ruined by flashing mining bios thanks to someone. as far as i searched since no one( xfx web , tpu , igor ) have the original bios for this model (which has Samsung memory)the only way i had was using RAW ii(similar xfx card) bios which has 1500 mhz memory frequency instead of 1750mhz( i flashed it and it was working all fine) .
i tried to use MPT tool to increase memory DPM 3 from 750 to 875(1750mhz) and make mpt file then write it into bios with red bios editor tool then flash it but no display output. as i said the bios is fine but doesn't work after i edit it . can someone please help for maybe edit the file himself ill put the bios in the attachment.
