INFO: Checking for updates on UserBenchmark.com
INFO: Version check passed
INFO: Benchmark engine running
INFO: Checking OS support
INFO: Checking CPU power status
INFO: Gathering Device Info
INFO: Starting CPU tests
INFO: Launching CPU benchmark suite
INFO: Running 1 core CPU benchmark ...
INFO: 1Core Int total throughput: 125.1
INFO: 1Core Float total throughput: 152.2
INFO: 1Core Mixed total throughput: 135.5
INFO: Running 2 core CPU benchmark ...
INFO: 2Core Int total throughput: 251.9
INFO: 2Core Float total throughput: 304.2
INFO: 2Core Mixed total throughput: 272.4
INFO: Running 4 core CPU benchmark ...
INFO: 4Core Int total throughput: 498.2
INFO: 4Core Float total throughput: 578.7
INFO: 4Core Mixed total throughput: 502
INFO: Running 8 core CPU benchmark ...
INFO: 8Core Int total throughput: 969.2
INFO: 8Core Float total throughput: 1129.2
INFO: 8Core Mixed total throughput: 1036.5
INFO: Running 64 core CPU benchmark ...
INFO: 64Core Int total throughput: 1992.6
INFO: 64Core Float total throughput: 2099.9
INFO: 64Core Mixed total throughput: 2138.5
INFO: Exiting CPU benchmark suite
INFO: Completed CPU benchmarks
INFO: Starting RAM tests
INFO: Launching RAM benchmark suite
INFO: Checking RAM configuration
INFO: Running 1 core RAM benchmark ...
INFO: 1Core Read total throughput: 25.7
INFO: 1Core Write total throughput: 23.6
INFO: 1Core Mixed total throughput: 34.3
INFO: Running 2 core RAM benchmark ...
INFO: 2Core Read total throughput: 39.4
INFO: 2Core Write total throughput: 24
INFO: 2Core Mixed total throughput: 38.4
INFO: Running 16 core RAM benchmark ...
INFO: 16Core Read total throughput: 45.8
INFO: 16Core Write total throughput: 41.4
INFO: 16Core Mixed total throughput: 35.4
INFO: Running system latency tests ...
INFO: 1KB memory latency: 1.05 ns
INFO: 2KB memory latency: 1.04 ns
INFO: 4KB memory latency: 1.05 ns
INFO: 8KB memory latency: 1.05 ns
INFO: 16KB memory latency: 1.04 ns
INFO: 32KB memory latency: 1.05 ns
INFO: 64KB memory latency: 2.08 ns
INFO: 128KB memory latency: 2.59 ns
INFO: 256KB memory latency: 2.87 ns
INFO: 512KB memory latency: 3.72 ns
INFO: 1MB memory latency: 7.33 ns
INFO: 2MB memory latency: 9.08 ns
INFO: 4MB memory latency: 10.07 ns
INFO: 8MB memory latency: 10.27 ns
INFO: 16MB memory latency: 25.92 ns
INFO: 32MB memory latency: 65.79 ns
INFO: 64MB memory latency: 73.07 ns
INFO: 128MB memory latency: 75.47 ns
INFO: 256MB memory latency: 80.41 ns
INFO: Exiting RAM benchmark suite
INFO: Completed RAM benchmarks
INFO: Gathering drive info
INFO: Launching Core drive benchmarks on C:
INFO: C: sequentialWrite 311.9 MB/s
INFO: C: sequentialRead 503.9 MB/s
INFO: C: sequentialMixed 317.2 MB/s
INFO: C: 4kRead 29.2 MB/s
INFO: C: 4kWrite 110.6 MB/s
INFO: C: 4kMixed 41 MB/s
INFO: C: 4k64thrRead 272.7 MB/s
INFO: C: 4k64thrWrite 275.4 MB/s
INFO: C: 4k64thrMixed 214 MB/s
INFO: Launching Core drive benchmarks on F:
INFO: F: sequentialWrite 366.9 MB/s
INFO: F: sequentialRead 396.7 MB/s
INFO: F: sequentialMixed 250.9 MB/s
INFO: F: 4kRead 27.4 MB/s
INFO: F: 4kWrite 69.1 MB/s
INFO: F: 4kMixed 27.8 MB/s
INFO: F: 4k64thrRead 207.9 MB/s
INFO: F: 4k64thrWrite 185 MB/s
INFO: F: 4k64thrMixed 199.6 MB/s
INFO: Launching Core drive benchmarks on E:
INFO: E: sequentialWrite 432.9 MB/s
INFO: E: sequentialRead 501.9 MB/s
INFO: E: sequentialMixed 423.3 MB/s
INFO: E: 4kRead 38 MB/s
INFO: E: 4kWrite 86.2 MB/s
INFO: E: 4kMixed 48.9 MB/s
INFO: E: 4k64thrRead 216.8 MB/s
INFO: E: 4k64thrWrite 185 MB/s
INFO: E: 4k64thrMixed 183.3 MB/s
INFO: Launching Core drive benchmarks on D:
INFO: D: sequentialWrite 86.7 MB/s
INFO: D: sequentialRead 432.2 MB/s
INFO: D: sequentialMixed 248.5 MB/s
INFO: D: 4kRead 26.7 MB/s
INFO: D: 4kWrite 94.6 MB/s
INFO: D: 4kMixed 46.8 MB/s
INFO: D: 4k64thrRead 218.5 MB/s
INFO: D: 4k64thrWrite 184.8 MB/s
INFO: D: 4k64thrMixed 199.1 MB/s
INFO: Launching Core drive benchmarks on G:
INFO: G: sequentialWrite 453 MB/s
INFO: G: sequentialRead 500.7 MB/s
INFO: G: sequentialMixed 304.4 MB/s
INFO: G: 4kRead 42.2 MB/s
INFO: G: 4kWrite 88.5 MB/s
INFO: G: 4kMixed 49.9 MB/s
INFO: G: 4k64thrRead 216.9 MB/s
INFO: G: 4k64thrWrite 185.8 MB/s
INFO: G: 4k64thrMixed 134.2 MB/s
INFO: Launching sustained write bench on C:
INFO: Launching sustained write bench on D:
INFO: Launching sustained write bench on E:
INFO: Launching sustained write bench on F:
INFO: Launching sustained write bench on G:
INFO: Checking GPU configuration
INFO: Launching SustainedWrite drive benchmarks on D:
INFO: Launching SustainedWrite drive benchmarks on C:
INFO: Launching SustainedWrite drive benchmarks on G:
INFO: Launching SustainedWrite drive benchmarks on E:
INFO: Launching SustainedWrite drive benchmarks on F:
INFO: Found 1 graphics card(s) and 2 active display(s)
INFO: Starting GPU Benchmarks
INFO: Launching NGPU detection
INFO: Launching AGPU detection
INFO: AGPU Name: AMD Radeon RX 6800 XT
INFO: AGPU Driver: 20.12.1
INFO: AGPU Bios: 020.001.000.043
INFO: AGPU Total RAM MB: 16368
INFO: Completed GPUStats successfully
INFO: Bench AMD Radeon RX 6800 XT @(ASUS MG278) on display(1) = main
ERROR: Plane GPU benchmark failed, aborting further tests on this GPU
INFO: Completed GPU benchmarks
INFO: Waiting for sustained writes ... 55
INFO: Waiting for sustained writes ... 54
INFO: Waiting for sustained writes ... 53
INFO: Waiting for sustained writes ... 52
INFO: Waiting for sustained writes ... 51
INFO: Waiting for sustained writes ... 50
INFO: Waiting for sustained writes ... 49
INFO: Waiting for sustained writes ... 48
INFO: Waiting for sustained writes ... 47
INFO: Waiting for sustained writes ... 46
INFO: Waiting for sustained writes ... 45
INFO: Waiting for sustained writes ... 44
INFO: Waiting for sustained writes ... 43
INFO: Waiting for sustained writes ... 42
INFO: Waiting for sustained writes ... 41
INFO: Waiting for sustained writes ... 40
INFO: Waiting for sustained writes ... 39
INFO: Waiting for sustained writes ... 38
INFO: Waiting for sustained writes ... 37
INFO: Waiting for sustained writes ... 36
INFO: Waiting for sustained writes ... 35
INFO: Waiting for sustained writes ... 34
INFO: Waiting for sustained writes ... 33
INFO: Waiting for sustained writes ... 32
INFO: Waiting for sustained writes ... 31
INFO: Waiting for sustained writes ... 30
INFO: Waiting for sustained writes ... 29
INFO: Waiting for sustained writes ... 28
INFO: Waiting for sustained writes ... 27
INFO: Waiting for sustained writes ... 26
INFO: Waiting for sustained writes ... 25
INFO: Waiting for sustained writes ... 24
INFO: Waiting for sustained writes ... 23
INFO: Waiting for sustained writes ... 22
INFO: Waiting for sustained writes ... 21
INFO: Waiting for sustained writes ... 20
INFO: Waiting for sustained writes ... 19
INFO: Waiting for sustained writes ... 18
INFO: Waiting for sustained writes ... 17
INFO: Waiting for sustained writes ... 16
INFO: Waiting for sustained writes ... 15
INFO: Waiting for sustained writes ... 14
INFO: Waiting for sustained writes ... 13
INFO: Waiting for sustained writes ... 12
INFO: Waiting for sustained writes ... 11
INFO: Waiting for sustained writes ... 10
INFO: Waiting for sustained writes ... 9
INFO: Waiting for sustained writes ... 8
INFO: Waiting for sustained writes ... 7
INFO: Waiting for sustained writes ... 6
INFO: G: sequentialWrite60 170.9 MB/s
INFO: E: sequentialWrite60 441.7 MB/s
INFO: C: sequentialWrite60 323.4 MB/s
INFO: F: sequentialWrite60 250.3 MB/s
INFO: D: sequentialWrite60 395 MB/s
INFO: Completed all benchmarks in 192 s
INFO: Shutting down benchmark engine
INFO: Results sent sucessfully
INFO: Your report is available online at:
INFO:
https://www.userbenchmark.com/UserRun/37036820
INFO: Opening report in default browser
Completed
