Hello
First, maybe a silly question. I'm not very familar with this tool. And also not with Windows. But is there an even more detailed documentation available about morepowertool?
Got an GIGABYTE RX 6600 EAGLE wich is generally overheating up to 105 degree in Celsius on MacOS by playing a game like by example Civilization 6. On Windows I get 85 - 90 degree. Prior I've never used morepowertool. Anyway this is not OK. By researching on the the internet to find an sulution, I got morepowertol as an recommendation in an another forum. Now I'm trying to fix my issue with morepowerool. But currently I did not get the card cooler. Maybe by lacking of knowledge about this tool I'm doing something wrong. I do not want under or overclock my graphiccard. I just wanna adjust even more proper fan settings. The fans are supposed to turn up to 4500 RPM's. I've seen and heared that by using a stresstest with the AMD Pro software. But unfortunately the fans are are turning much more slower currently.
The issue exists on Windows and on MacOS. Disabling or enableing Zero RPM works well. On Windows and by the extracted hex on MacOS too as well. Could any one give me some hints to get faster fan speeds?
cheers Darko
![Features.png Features.png](https://www.igorslab.de/community/data/attachments/29/29858-dd7176b0969acfa758ab3945611f8c36.jpg)
cheers Darko
