hello I have a gigabyte rx 5700 xt gaming oc with samsung memories, someone knows if there is an unlocked BIOS for this board with these memories. because the ones I found are for micron memories. I attach bios stock in case it works for someone.
Hello and welcome,hello I have a gigabyte rx 5700 xt gaming oc with samsung memories, someone knows if there is an unlocked BIOS for this board with these memories. because the ones I found are for micron memories. I attach bios stock in case it works for someone.
You are welcome.thanks for the reply
Hello I have a gigabyte rx 5700 xt gaming oc with samsung memories, someone knows if there is an unlocked BIOS for this board with these memories. because the ones I found are for micron memories. I attach bios stock in case it works for someone.h
hello broo....Is the file you attached the stock bios for gigabyte with Samsung memory?hello I have a gigabyte rx 5700 xt gaming oc with samsung memories, someone knows if there is an unlocked BIOS for this board with these memories. because the ones I found are for micron memories. I attach bios stock in case it works for someone.
