Hi all,
I am trying to mod this bios for mining. I have a lot of these cards but all the others had Micron Memory and modded fine.
With this attempt I only changed the straps above 1550mhz (copied the straps from 1550mhs to 1800, 2000 and 2250mhz) then used the hiveos flashing tool and forced flash option. Hive says it flashes okay then when i reboot it won't recognize the card. I am then able to reinstate the card with the original bios.
![1623288809760.png 1623288809760.png](https://www.igorslab.de/community/data/attachments/13/13202-c3d87a0c848b36cf0bdb4a243d02383c.jpg)
I suspect it is a locked bios. I had a similar issue with an asus rog strix 5700 xt (also samsung mem). I had to find a much earlier bios version and modify it to get it to work. @minime you seem to have helped a lot of people with similar issues. Would be awesome if you or anyone else can help please.
