Question GIGABYTE 5700 XT Bios mod fails
AlleyCat
Hi,
I am failing to update Gigabyte 5700 XT. The same procedure updates the BIOS on MSI cards with no problem. I follow the instructions on Igors Lab.
The sign of having trouble with the card bios flash shows in GPU-Z. After flash using amdvbflash the values of GPU and memory frequencies is empty. With stock bios there are Mhz frequencies.
Is there any known problems with flashing Gigabyte cards?
Any suggestions on what other forums I may ask for assistance?
Is it possible that the OEM bios is signed, and any modified bios will be rejected?
If the bios is signed, any tools to resign, or would I need to buy a card from a different vendor?
Thanks,
Alley Cat
Is just this card, can't pass 890 mhz. It was like this from the beginning... doesn't matter what I change.
Thank you Igor! I flashed all my four gigabyte gaming oc cards and working good but working at 55 mh/s and 5% stales. I used to have 1 or 2%.
I'd like to get more mh and less stales. How can I troubleshoot that?.
In case I want to try a different bios, can I flash another with standard method or I need to always use amdvbflash you provided for windows?
Thank you again!
Thank you Igor! I flashed all my four gigabyte gaming oc cards and working good but working at 55 mh / s and 5% stales. I used to have 1 or 2%.
I'd like to get more mh and less stales. How can I troubleshoot that ?.
Thank you again!
You are welcome,
Please use the latest vbios version v68 for Gigabyte RX 5700 XT GAMING in the kindly attached link bellow,
Yes, that's the version I used and modified with your instructions.
But I have those problems I told you.
Is it possible to flash over that modded rom with standard method. So I try different memory straps?
Also, any other suggestion?
What are your HiveOS parameters setting you are currently using?
Please could you post a screen shot.
Phoenix miner is inacurate in hashrate! You need to adjust the system now, has trm use diferent kernel. Every time you make a change, reboot miner to create new dag file.
Now, with teamRedMiner, 1430/800 I can't get more than 55mh/s
Please use the setting below for stable 24/7 operation,
Core clock, VDD : Memory clock, VDDCI, MVDD, Hashrate
For Samsung and Micron,
1390 MHz, 780 or 790 mV : 910 MHz, 850 mV, 1350 mV, 55.90 MH/s,
1380 MHz, 770 or 780 mV : 900 MHz, 840 mV, 1350 mV, 55.60 MH/s,
For Micron
1415 MHz, 790 or 800 mV : 935 MHz, 875 mV, 1350 mV, 57.10 MH/s,
1430 MHz, 800 or 810 mV : 950 MHz, 890 mV, 1365 mV, 58.10 MH/s.
You can adjust all low and stable, or independent and see what gives for each card. Sometimes the same card performs diferent from each other. You need to test. I sincerly hope that you achive the best result as much as you can!
For Micron
Thank you, but saddly I adjust with best micron settings and can't get more than 55,4. And unstable.
Also, more power and temp on memories, but not better performance.
Well, sometimes is what it is. We can get different performance with the same card.
I'm using this settings on hiveos for two cards:
C1390 / CV790 / VDDCI850 / M910 / MVDD 1350 ~56mh
And other for the "not so god" card:
C1390 / CV790 / VDDCI850 / M890 / MVDD 1350 ~54mh
