2024-05-10 13:18:47, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->
2024-05-10 13:18:47, Info DISM DISM.EXE: Host machine information: OS Version=10.0.22631, Running architecture=amd64, Number of processors=16
2024-05-10 13:18:47, Info DISM DISM.EXE: Dism.exe version: 10.0.22621.2792
2024-05-10 13:18:47, Info DISM DISM.EXE: Executing command line: DISM /Online /Cleanup-Image /RestoreHealth /Source:wim:c:\ISO\sources\install.wim:1 /limitaccess
2024-05-10 13:18:47, Info DISM DISM Manager: PID=1952 TID=6252 physical location path: C:\ - CDISMManager::CreateImageSession
2024-05-10 13:18:47, Info DISM DISM Manager: PID=1952 TID=6252 Event name for current DISM session is Global\{02C40B64-1AA3-453E-8850-8D69DB6AC6BB} - CDISMManager::CheckSessionAndLock
2024-05-10 13:18:47, Info DISM DISM Manager: PID=1952 TID=6252 Create session event 0x264 for current DISM session and event name is Global\{02C40B64-1AA3-453E-8850-8D69DB6AC6BB} - CDISMManager::CheckSessionAndLock
2024-05-10 13:18:47, Info DISM DISM Manager: PID=1952 TID=6252 Copying DISM from "C:\WINDOWS\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2024-05-10 13:18:47, Info DISM DISM Manager: PID=1952 TID=6252 No Sandbox was created, DISM running in-place. - CDISMManager::CreateImageSessionFromLocation
2024-05-10 13:18:47, Info DISM DISM Manager: PID=1952 TID=6252 Successfully loaded the ImageSession at "C:\WINDOWS\System32\Dism" - CDISMManager::LoadRemoteImageSession
2024-05-10 13:18:47, Info DISM DISM Image Session: PID=34072 TID=20388 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2024-05-10 13:18:47, Info DISM DISM OS Provider: PID=34072 TID=20388 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2024-05-10 13:18:47, Info DISM DISM OS Provider: PID=34072 TID=20388 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2024-05-10 13:18:47, Info DISM DISM Provider Store: PID=34072 TID=20388 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2024-05-10 13:18:47, Info DISM Initialized Panther logging at C:\WINDOWS\Logs\DISM\dism.log
2024-05-10 13:18:47, Info DISM DISM Provider Store: PID=34072 TID=20388 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2024-05-10 13:18:47, Info DISM DISM Manager: PID=1952 TID=6252 Image session successfully loaded from location: C:\WINDOWS\System32\Dism - CDISMManager::CreateImageSession
2024-05-10 13:18:47, Info DISM DISM.EXE: Target image information: OS Version=10.0.22631.3296, Image architecture=amd64
2024-05-10 13:18:47, Info DISM DISM.EXE: Image session version: 10.0.22621.1
2024-05-10 13:18:47, Info DISM DISM Transmog Provider: PID=34072 TID=20388 Current image session is [ONLINE] - CTransmogManager::GetMode
2024-05-10 13:18:47, Info DISM DISM Transmog Provider: PID=34072 TID=20388 Audit Mode: [No] - CTransmogManager::Initialize
2024-05-10 13:18:47, Info DISM DISM Transmog Provider: PID=34072 TID=20388 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2024-05-10 13:18:47, Info DISM DISM Transmog Provider: PID=34072 TID=20388 Product Type: [WinNT] - CTransmogManager::Initialize
2024-05-10 13:18:47, Info DISM DISM Transmog Provider: PID=34072 TID=20388 Product Type ServerNT : [No] - CTransmogManager::Initialize
2024-05-10 13:18:47, Info CSI 00000001 Shim considered [l:126]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.22621.3364_none_e95597ea42d42c72\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2024-05-10 13:18:47, Info CSI 00000002 Shim considered [l:123]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.22621.3364_none_e95597ea42d42c72\wcp.dll' : got STATUS_SUCCESS
2024-05-10 13:18:47, Info DISM DISM Driver Manager: PID=34072 TID=20388 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2024-05-10 13:18:47, Info DISM DISM Package Manager: PID=34072 TID=20388 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2024-05-10 13:18:47, Info DISM DISM Package Manager: PID=34072 TID=20388 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\CBS\CBS.log - CDISMPackageManager::Initialize
2024-05-10 13:18:47, Info DISM DISM Package Manager: PID=34072 TID=20388 Loaded servicing stack for online use. - CDISMPackageManager::CreateCbsSession
2024-05-10 13:18:47, Info DISM DISM Package Manager: PID=34072 TID=20388 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler:
rivate_ValidateCmdLine
2024-05-10 13:18:47, Info DISM DISM Package Manager: PID=34072 TID=20388 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2024-05-10 13:18:47, Info DISM DISM Package Manager: PID=34072 TID=20388 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2024-05-10 13:18:47, Info DISM DISM Package Manager: PID=34072 TID=20388 CBS session options=0x20100! - CDISMPackageManager::Internal_Finalize
2024-05-10 13:20:13, Info DISM DISM Package Manager: PID=34072 TID=18960 Error in operation: source for package or file not found, ResolveSource() unsuccessful. (CBS HRESULT=0x800f081f) - CCbsConUIHandler::Error
2024-05-10 13:20:13, Error DISM DISM Package Manager: PID=34072 TID=20388 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x800f081f)
2024-05-10 13:20:13, Error DISM DISM Package Manager: PID=34072 TID=20388 The source files could not be found; their location must be specified using the /source option to restore the feature. - GetCbsErrorMsg
2024-05-10 13:20:13, Error DISM DISM Package Manager: PID=34072 TID=20388 Failed processing package changes with session options - CDISMPackageManager::Internal_ProcessChangesWithOptions(hr:0x800f081f)
2024-05-10 13:20:13, Error DISM DISM Package Manager: PID=34072 TID=20388 Failed processing package changes with session option CbsSessionOptionRepairStoreCorruption - CDISMPackageManager::RestoreHealth(hr:0x800f081f)
2024-05-10 13:20:13, Error DISM DISM Package Manager: PID=34072 TID=20388 Failed to restore the image health. - CPackageManagerCLIHandler:
rocessCmdLine_CleanupImage(hr:0x800f081f)
2024-05-10 13:20:13, Error DISM DISM Package Manager: PID=34072 TID=20388 Failed while processing command cleanup-image. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x800f081f)
2024-05-10 13:20:13, Info DISM DISM Package Manager: PID=34072 TID=20388 Further logs for online package and feature related operations can be found at %WINDIR%\logs\CBS\cbs.log - CPackageManagerCLIHandler::ExecuteCmdLine
2024-05-10 13:20:13, Info DISM DISM Package Manager: PID=34072 TID=20388 Finalizing CBS core. - CDISMPackageManager::Finalize
2024-05-10 13:20:13, Info DISM DISM Manager: PID=1952 TID=6252 Closing session event handle 0x264 - CDISMManager::CleanupImageSessionEntry
2024-05-10 13:20:13, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2024-05-10 13:20:13, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
