Hi all,
I have some weird behaviour with my Gigabyte RX5700XT. I bought this pre-owned card, installed and tried to use with Linux and Win-10 alike.
Generally, the card works fine with normal desktop and gaming, frame rates seem to be ok + normal for a 5700xt.
But I tried to use the card as openCL computing node (i.e. ETH mining), and there it is:
- with linux and proper drivers/packets, GPU is either recognized, but mines with "0 H/s" constantly, or the mining program (ethminer or trm) hangs when initializing the GPU
- with win-10 and latest drivers fom AMD support pages, the GPU was recognized by ethminer or claymore (after adding a registry dword key giving the location of opencl.dll), but it hangs when initializing the GPU
- "amdvbflash -i" (v3.04+ from Igors download page) hangs too (just shows "AMDVBFLASH version 3.04+EXTERNAL" line, then hangs),
but the amdvbflash provides by AMD ("BIOS correction tool" package, unknown version of amdvbflash) runs fine and gives infos as expected:
![1615803848690.gif 1615803848690.gif](https://www.igorslab.de/community/data/attachments/11/11896-e2a05f070a52b63a84792b7894f42b55.jpg)
Strange to me: the "OpenCL" box is unchecked, and cannot be activated.
Any ideas? Is that normal behaviour??
Thx.
And GPU-Z shows:Adapter 0 (BN=03, DN=00, FN=00, PCIID=00001002, SSID=00002313)
Asic Family : Navi10
Flash Type : W25Q80 (1024 KB)
Product Name is : GV-R57XTGAMING OC-8GD/F3/0921
Bios Config File: R57XTGO.F3
Bios P/N : P/N Not Available
Bios Version : 017.001.000.049.000000
Bios Date is : 08/28/19 21:51
Image 1 -- Offset 0x0
ROM header contents:
Signature 0xAA55
PCIR offset 0x02D8
PCI Data Structure
Signature PCIR
Vendor ID 0x1002
Device ID 0x731F
PCI Revision 0x00
Image size 0xE000
Code revision 0x1101
Indicator 0x00 (Not last image)
Code type 0x00 (PCAT Image)
Legacy BIOS File Name R57XTGO.F3
Legacy BIOS Part Number xxx-xxx-xxx
Legacy BIOS Build Number 478710
Legacy BIOS Change List 1990669
Binary BIOS_IDTF 0xAE0A631F
ByteCheckSum 0
Image 2 -- Offset 0xE000
Signature 0xAA55
PCIR offset 0x001C
PCI Data Structure
Signature PCIR
Vendor ID 0x1002
Device ID 0x731F
PCI Revision 0x00
Image size 0xAC00
Code revision 0x0000
Indicator 0x80 (last image)
Code type 0x03 (EFI Image)
EFI Signature 0x0EF1
Compression Type 0x0001 (compressed)
Machine type 0x8664 (X64)
Subsystem 0x000B (EFI boot service driver)
EFI image offset 0x0058 (abs: 0xE058)
Uefi Ids from EFI_PCI_EXPANSION_ROM_HEADER:
UefiSourceRevision GOP AMD REV: x.x.x.x.x
UefiSourceChangeList xxxx
UefiBiosBuildNumber xxxx
Dump Gop Driver Info:
Machine type code X64
The GOP Driver appears to be Authenticode signed.
Size Of Gop Image 65248 (63 KB)
GOP Driver Name: AMD GOP X64 Release Driver Rev.2.8.0.0.0.Jul 26 2019.11:24:53
GOP AMD_Build 2218
GOP AMD_CL 1974379
GOP BIOS_IDTF 0xDEADBEEF
GOP Driver does not carry tables!
Thx.
